VST adding 2 bars
2003-01-09 by erik_magrini@Baxter.com
You need to change the preroll amount (or is it the start offset?) it
sounds like (the default is 2 bars). I think that's under the
synchronization menu in VST.
rEalm
"Loops / La Bloukak" <bloukak@...>
01/09/03 04:14 AM
Please respond to xl7
To: xl7@yahoogroups.com
cc: Show quoted textHide quoted text
Subject: [xl7] Re: MIDI editor Hi all and thx for tips... i have the same problem with Cubase, when i export my file under .mid SMF, cubase put 2 blank bars at the beginning of the file, and of course it doesn't loop in the machine sequencer... does anybody has a solution ? maybe change of sequencer, but i will prefer another solution of course ;o) Loops ----------------- Message: 17 Date: Wed, 8 Jan 2003 20:38:11 -0600 From: "David DeciBel" <spec@...> Subject: Re: MIDI editor Can anyone recomend a good simple MIDI editor for editing text & sysex from my xx7? I use CUBASE but it's a bit large to edit plus i'm having some problems exporting to smf... To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
