How ??
2003-01-27 by kevinj_j <kjohnson@fncinc.com>
I was listening to the emuCS and I came up with a question.. How do you guys program your brak beats realtime? grid? a mixture? mine ALWAYS sound LAME..any pointers?
2003-01-27 by David
My tracks are usually between 130 and 171 bpm. I used to be a drummer, which helps a lot, but it's just a matter of putting what you want in your head and just doing it. Usually I have to slow my track down to 50% before recording it. listen to the drums you have and find a place for them in your break... Also filters have a lot to do with great sounding drums. My best drum lines are usually done on 1 track because I can control the whole "kit" - Don't be affraid to build your own kits - the XX-7 can layer 4 sounds per preset and you can stak 4 presets at a time. so you can put that special kick with that phat tom and that punchy snare... The ERASE button is a saviour too - "which drum in the break just doesn't go well" and erase it - To answer your question more fully, I usually start by recording a 2 or 4 measure loop in real mode (slow) then add different things in grid mode. Then I extend that pattern to 8 or 16 measures and move things around. Take that snare drum and put it on the 1/8th note instead of the 1/4 note, mix the hats around a little... Never be afraid to try something new ... There's always REVERT... Ok, just because I have the day off, doesn't mean I can sit in this forum and write messages all day... back to the purple box. ----- Original Message -----
From: <kjohnson@...> To: <xl7@yahoogroups.com> Sent: Monday, January 27, 2003 10:08 AM Subject: [xl7] How ?? > I was listening to the emuCS and I came up with a question.. > How do you guys program your brak beats realtime? grid? a mixture? > mine ALWAYS sound LAME..any pointers? > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@yahoogroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > > >
--- In xl7@yahoogroups.com, "David" <spec@s...> wrote: > Also filters have a lot to do with great sounding drums. could you explain this a little.... thanx for the tips
