problems with sends?
2003-02-20 by nodalterror
i currently have the xx-7 hooked up to a bunch of guitar pedals using
the external sends.. now, i'm using insert cables... the ones where
it's a 1/4 plug that goes out through the tip and comes back into via
the ring... now since most of the pedals i'm using are mono inputs,
does that mean that if i only have one insert going out of each
external sub output (left) that the returning signal will only come
back on the left channel?
Re: problems with sends?
2003-02-20 by mikexl7 <curiousproductions@rogers.com>
Yes you would only get the left channel.  One thing you could do is
split the outupt of the pedal into a dual mono and send em back into
the left and the right.  The problem is that you would only get the
signal of the left channel coming in on both.  I hope i am
understanding you right.
And hope that helps.
Mike G.
using
where
via
inputs,
come
