Key to pitch
Key to pitch
2003-02-25 by kmusard <kmusard@yahoo.com>
The MP7 manual states that key position is hard wired to pitch.  On
the MC505 there is a patch parameter called key follow which allows
you to adjust how much the pitch changes as the key position
changes.  By setting this parameter to 0 you have the same pitch on
each key.  Does anyone know how to set the patch cords up to
accomplish this?  I want to be able to have the pitch stay constant
on each key, be able to have the pitch change by 1 octave over 24 or
36 keys, etc.  I would also like to be able to reverse the direction
of pitch change (notes get deeper as you go up the keyboard).
Re: [xl7] Key to pitch
2003-02-25 by Aaron Eppolito
Depending on what you want to do, there's a few ways to accopmlish it.
If you want simple non-transposition (i.e. same pitch every key)
there's a preset parameter called "NON-TRANSPOSE" in the preset edit
menu.  This plays all samples at unity pitch (which will chaneg over
the keyboard for multisamples)
From there, you can hook a patchcord from Key (any variant) to Pitch
and/or Fine Pitch to achieve other scalings.
However, if you're simply trying to get different tunings (i.e quarter
tones, 24 keys to an octave), there are alternate tunings that you can
select in the preset, near the end of the menu.  There's a whole
selection of factory tunings along with 12 slots for you to make your
own.
To make your own, in the Global menu, the alternate tunings page is
where you can edit them.
For drums/SFX where you want the pitch to change slowly, I'd recommend
the first method of approach, namely enabling non-transpose, and then
hook a cord from Key+- -> Pitch.  For doing your quarter-tone tuning,
I'd recommend making and using a user tuning table.
-Aaron
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
Oh, by the way, you could hook up Key+- -> Pitch with a negative amount
to counteract the built in key scaling.  You don't need to enable
non-transpose to be able to do that.  In fact, for multisamples, it'll
work better if you leave non-transpose disabled.
-Aaron
Do you Yahoo!?
