Grid record problem
2003-03-12 by Justin Grimley
I have a recurring problem that is really buggin' me! Sometimes (not all the time) when I select a track then go into grid record mode, hit play, select a pad then switch on the triggers for the beats I want, the wrong sound will play. Usually I get the sound assigned to the pad one octave above the one I selected. If i change the transpose this does not help. However, if i change the pattern to say the previous pattern preset and then back to my user pattern, the problem goes away. Did this make sense? Anyone know what is going on? Thanks, grimley.
