RE: [IBGEEK] slow rising acid sound
2003-03-13 by Andre Lewis
Well I am cc'ing this question to the XL7 group there are some pretty cool peeps
on that list.  You basically take the soundyou want set the resonance to like
45% ish then you apply a patchcord to the cuttoff, since you want acid lines you
will get better results if you choose a saw based sound and play with different
filters until you find one with a steep enough curve for good self resonance.
The key to getting sounds like that is actually to apply  some distortion
(Actually overdrive is better) to the signal after the filters and before the
effects.  You might want to look at getting a guitar pedal that does that later
on, specifically a rectifier or bit reduction, then using an insert cable on the
output 2 section.
Someone else might have a better formula for this on the xl7 list.  If you
respond to this guys make sure you do a reply all for honkeyhindu... I don't
think he's on the xl7 list.
Andre
Sent: Thursday, March 13, 2003 9:42 AM
To: IBGEEK@yahoogroups.com
Subject: [IBGEEK] slow rising acid sound
hello all ..i am trying to programm a slow rising growling acid
sound ..if anyone has heard uberzone they should know what i am
taking about. if some one can explin a general way of creating a slow
riising sound i guess it would srat me off .  i will try and post a
sample of the wave tonight..oh yea  just incase..i ma trying to do
this with the xl7.
IBGEEK-unsubscribe@yahoogroups.com
