WHAT THE F@#$!!!
WHAT THE F@#$!!!
2003-03-26 by jibarosoul@aol.com
=( I BROKE MY MP-7! ONE OF MY PADS RIPPED OFF OF THE SURROUNDING RUBBER AND
CAME COMPLETELY LOOSE. I PUT IN A PART INQUIRY AT EPR ELECTRONICS WEB SITE A
COUPLE DAYS AGO. TODAY I RECEIVED A CALL BACK AND THE LADY SAID THE PART COST
$204.00!! WHAT!!! I TOLD THE LADY THAT SHE MUST HAVE MADE A MISTAKE. SHE
TELLS ME THAT SHE ORDERED THE COMPLETE PAD ASSEMBLY SO I EXPLAINED TO HER
THAT ALL I NEED IS THE RUBBER PAD STRIP. SHE SAID SHE WOULD CANCEL THE ORDER
AND LOOK INTO IT FURTHER. SURELY THIS PIECE OF RUBBER CANT BE $204.00. THAT'S
INSANE!! I KNOW WERE IN AN ECONOMIC SLUMP, BUT COMMON! NEED HELP, I CANT BEAT
ON MY KICK DRUM PAD!
Re: [xl7] WHAT THE F@#$!!!
2003-03-26 by erik_magrini@Baxter.com
You can Transpose the Keypads in the Controllers Menu, so at least for now
you can beat on the kick drum pad.  :)   That does suck about the price,
are you sure they can send you just the rubber part?
rEalm
AND
A
COST
ORDER
THAT'S
BEAT
She said she would check it out. I think she ordered the entire keypad
assembly (including the curcuit board). Good idea about the transpose
settings, will I need to save the preset if thats the only edit I make? Also,
you took your XL-7 apart, were you able to seperate the rubber pad strip from
the rest of the part? Thanks for your help man!!
2003-03-26 by Aaron Eppolito
The rubber part is easily detachable from the circuit board.  It was
designed that way explicitly for this purpose; to make replacement easy
and cost-effective if necessary.  You should be able to purchase just a
new rubber to replace your ripped one...  uh...
-Aaron
--- jibarosoul@... wrote:
> Also, you took your XL-7 apart, were you able to seperate the rubber
> pad strip from the rest of the part? Thanks for your help man!!
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
Too late by then usually...
rEalm
You should be able to purchase just a new rubber to replace your ripped
one...  uh...
-Aaron
WHERE CAN I ORDER ONE? THE LADY AT EPR HAS NOT RETURNED MY CALL.
Seems like an obvious question, but did you try calling E-mu?
Do you Yahoo!?
