OS 2.0 Bug?
2003-04-11 by erik_magrini@Baxter.com
Tried something last night and kept getting weird results, not sure if it's a bug or not... Basically I wanted to use the Repeat button to create a snare roll with the Preset assigned to Track 2. I had already recorded some snare stuff on track 2, so I muted the track and then pressed the Repeat button. Made sure the Rec Quantize was set to 1/16th notes, left Rec Mode, then pressed a pad. Nothing happened. Then, as soon as I press Repeat again, it unmuted Track 2! Basically, I'm getting some really weird itermittant behavior using the Repeat button on Track that are muted. Either the Repeat won't work right, or it unmute my track. sometimes I have to go back into Rec Mode and out again to get it to work this way. Anyone seen anything like this? rEalm [Non-text portions of this message have been removed]
