Please HELP
Please HELP
2003-04-11 by emailba
Hi there yahoo group this is actualy a post from mikexl7 being posted
by my good friend Ba.
I have been trying to post this question for over a week now but i
cant for some unknown reason.
Yahoo is messed for me at the moment. What you are about to read is
the reply I got from emu tech support.
The second section is what I sent them. As you can see for yourself I
did not get my question answered.
So i am begging you Aaron or Scott please let me know if i can use
the Pocket Dial from doepfer to get around the problem
of jumping values in my live proformance. I have emailed emu and
deopfer and I still have no answer to this queston.
Dear Michael,
There are several things to consider as it concerns this question.
1) All Proteus family products and EOS samplers support realtime
control
of many features *(this you know). There is no way to bypass the
INITIAL
controller levels set in the preset as these will setup the preset's
unique 'sound characteristics'.
2) As for POCKET CONTROL... I can only state that the Proteus family
of
products...including the Command Stations, will support standard
realtime CC data. As for the POCKET CONTROL issues of 'feedback' I
cannot answer this... I suppose the POCKET CONTROL would use sysex to
request the status of a controller??? I don't know that one. This in
mind we can only recommend standard midi controllers and if the
POCKET
CONTROL is sending standard CC data then it should work.
3) If the preset is not to your liking...then edit it so that it will
work better in the context of performance. I.e., set you INITIAL
CONTROL
levels to 000 and then rely on the quick edit or program knobs
to 'set
it up' realtime like and older analog synth. That or use the presets
way they are now and modify your performance to match the abilities
of
the instrument.
Regards;
E-MU Systems Inc.
Technical support
Original Message Follows:
Customer Information
Email Address: curiousproductions@...
<mailto:curiousproductions@...>
Country: Canada
E-MU Product Information
Customer Type: End User
Desktop Products: Not Specified
Sound Modules: ORBIT 3
Command Station: XL-7
Keyboards: Not Specified
EOS Samplers: E5000 ULTRA
Vintage E-MU Musical Instruments: Not Specified
Operating System Version: XL-7 2.0
Model Number:
Problem lies with:
XL-7
Customer's System Specification:
Computer Type: WIN
CPU/RAM: 512
Operating System: xp
Detailed Hardware:
Detailed Problem Description:
I need to know if the Command station can
work properly with the Doepfer Pocket Dial.
I am going to paste in sompthing that I
have read it says it better than I can.
"POCKET CONTROL that is equipped with 16
rotary potentiometers. This enables a jump-
less change of parameters provided that the
device or software controlled by POCKET
DIAL features data feedback of the new
starting data after a preset change as
POCKET DIAL needs the starting values of
theparameters of the new preset. Another
possibility is the increment/decrement
control of the parameters in question. In
this case the POCKET DIAL does not "know"
the absolute values of the parameters but
transmits only inc/dec data to the
device/software. Only devices that
features the data feedback or inc/dec
control should be controlled by POCKET
DIAL." Ok that summes it up pretty will I
thought. So will I get smooth flowing CC
changes when using the pocket dial? If not
I would love to see this changed so that
one could use this type of controller with
the command stations. Other that or have
it set up so that the pots on the command
station dont do anything till the current
value is met. And then have the controller
take hold. I don't want to sound like a
pest but using the real time edit knobs
they way they are in a live show is very
anoying at best, and often just not an
option due to the looming sudden changes.
My music relies very much on live tweaking
of the synth.
Sorry for the long email but I can't stress
the imprtance of this to me enough.
Thank you very much for your time. I look
forward to your reply very much.
Mike Goodwin
Re: Please HELP
PS     please reply at curiousproductions@... only or i cant
get back to you.  Thank you.
posted
I
> Dear Michael,
> control
> INITIAL
preset's
family
> of
to
in
> POCKET
will
> CONTROL
> to 'set
presets
> the
> of
> the instrument.
> Regards;
> E-MU Systems Inc.
> Technical support
> Email Address: curiousproductions@r...
> <mailto:curiousproductions@r...>
> Country: Canada
> Model Number:
> Problem lies with:
> XL-7
> Computer Type: WIN
> CPU/RAM: 512
> Detailed Hardware:
> of the synth.
> Mike Goodwin
