LAtency while slaving MP7 ????
2003-04-22 by Umesh Bhagwat
Dear Sir,
Hello how are you ? I hope all is fine at your end.
We are the sole distributors for EMU/Ensoniq  in INDIA.
This is my first  tech query to you  on the MP7  command station.
The  O.S ver of  MP7  is  1.32
One of our customer is facing problem while slaving the MP7 to AKAI's
 MP60 MK2 :
Settings of the MP60mk2   and MP7 given below :
(MASTER)  AKAI Mp60 mk2 midi out going into midi in of Mp7 (SLAVE) .
MP7  is set to song mode, when I  hit the play button on the MP60
mk2,there is a
latency while triggerring the mp7 and also there is an overlapping of
sounds (double sound).
Why is it so ?
Am I missing something on the settings part  on the Mp7.Please let us know.
Your help is needed urgently.
Waiting for your reply
Thanks and best regards
for S.U.N. Media Ventures Pvt Ltd.
Peter
Re: [xl7] LAtency while slaving MP7 ????
2003-04-22 by erik_magrini@Baxter.com
Is the MP60 sending any Midi note data to the MP-7, or just Midiclock
signal?  If they are trying to use the Mp-7 just as a sound module, then
make sure you go into the MIDI menu and set the MP-7 to ignore "External
Song Start/Stop" commands.  You may also want to turn off Rechannelize
input, and make sure the tempo is set to 0 (Ext).  If you can tell us some
more about what your customer is trying to do with both boxes, it might be
easier for us to see why this isn't working.
Also, is there a midi cable from the MP-7 MIDI out to the MP60 Midi In?
That could be causing a MIDI loop if there is one there currently.  One
more thing, if you check in the files section of this group, you'll find
OS 2.0, might want to update the MP-7 with that too.
rEalm
Dear Sir,
 MP60 MK2 :
mk2,there is a
Why is it so ?
know.
Peter
