to sean: future OS suggestions
2001-11-24 by barleyqueen2001@yahoo.com
the xl is a truelly beautiful machine but what i really miss on the
xl-7 is
: the possibility to edit an existing rom drumkit where you can
assign a single note to a single output. kik bus 1 left, snare bus 1
right etc..
now you need to make a kit for every bus assigned: kit one aux 1 left
only for the single sounds. takes ages and is very inefficient
: the possibility to filter only a single drumsounds in stead of the
whole kit: implent a filter option: single note filter?!
: the possibility to use the spdif output as a single bus, so you
have not 6 but 8 outputs. if you work with a seperate mixin desk
and you split the drums into kik. snare. hats., bass., and
percussion., you don't have any space left fot the pads,fx etc. By
making the digtal out an extra output bus you can mix the whole thing
without compromising on the drums. the output is theire why not use
it!
: deleting a pattern function, where is it?
cheers for the support until now, which is great
Shabby InC
