The SPDIF outputs are quiet by design. The idea is that if you
have some really wacked-out filtering going on, your resonance
could get so loud that it would clip, so EMU dampened the
SPDIF output.
As for having the same problem when using the 1/4" jacks, I
don't know what to tell you. I use 1/4", and I actually have to turn
my XL7 down in order to hear the other gear in my setup.
Clay
--- In xl7@yahoogroups.com, "pranaearth" <pranaearth@y...>
wrote:
> Thanks for your reply Jesse,
> I am using the SPDIF output directly into the SPDIF in of my
> soundcard.
> In the mixer applet for the soundcard, the SPDIF volume is
turned
> all the way up.
> The meters are registering at around 10 when I play mt XL7.
> This is with my volume knob on the XL7 turned al the way up,
and
> with the indiviual volume of each track turned all the way up.
> In contrast, my volume slider on my Karma, and XP60 are
turned 3/4
> of the way up, with the volume slider in the applet turned to 3/4
of
> the way up, and the meters are going into the red and the
sound is
> distorting.
> The problem exist if I use 1/4 inch cables too.
> I just don't understand how this beast can be so quiet.
> prana
> --- In xl7@yahoogroups.com, "jesse_medway"
<medway808@h...> wrote:
> > Not sure what you are doing wrong but the xl-7 is fine volume
wise.
> > If its not the volume knob then maybe you have a midi volume
set
> low
> > or the input of you mixer etc... i set lower.
