WinXP & USB Problem
WinXP & USB Problem
2003-06-05 by justinkoller
I've seen some people post about this, but haven't seen a solution
or heard of one working.
When i turn on the XL7, let it boot up, and THEN plug it into
windows (as the directions say), windows xp will NOT correctly
detect the device.  Via MIDI, I have already upgraded to 2.0, and
can run eloader.  Eloader was not running while I tried to plug in
the device to USB.
Emu support has some canned response they used on me twice that
includes "USB is only for sequence back up" and "please read the
instructions and follow them exactly or you'll need to douse your PC
in bleach and reinstall windows".  So I'm turning to you guys.
I've tried this on several PC's (all, unfortunately, run winXP).
Every one complains that an "unknown device" was plugged in, and may
have malfunctioned.  Manual installs fail, because windows complains
the drivers I try to set (tried both usb0 and usb1 first) an
incompatible with the device..I'm guessing that's because
it's "unknown".
But, I'm thinking that the device has some unique ID, (since
subsequent install attempts happen so much faster than the first)
and that I can edit the registry settings for it, so windows can
match up the same strings that exist in the driver vs. what's
detected.
A.) Anybody got another solution?
b.) What, EXACTLY, does windows XP detect the device as?
thanx
-jk*
Re: [xl7] WinXP & USB Problem
2003-06-05 by erik_magrini@Baxter.com
Hmm strange that you're having problems with XP, works fine for me.  Try
this:
- Plug in the XL-7 to the USB port.
- Go to Start -> Settings -> Control Panel -> System -> Hardware -> Device
Manager.
- Open the drop down menu for Universal Serial Bus Controllers, and you
should see yellow X's on two of the unknown devices correct?
- Double click on one of them and select Properties, then Update Driver.
- Choose the optiont hat lets you specify the location manually, then
navigate to the "USB Drivers" folder in your E-Loader Folder.  Go through
all fo the prompts and it should install the driver and show up as
"Interface 0". Repeat for the otehr unknown USB device, and it shoudl show
up as "Interface 1".
Hope that helps!
rEalm
the device to USB.
it's "unknown".
detected.
thanx
-jk*
Re: WinXP & USB Problem
I guess I'm beginning to think my XL-7 has a bunk USB interface.
I don't get yellow X's on the two unknown devices...I get 1 device,
labelled "unknown device", listed under "USB controllers", updating
the driver always results in windows complaining that the driver
selected (...USB0.inf) is not compatable with the device.  I have the
two USB0 & 1 inf files, along with the actual .sys driver.
What type of device is the XL-7 supposed to be? (have the unknown's
shown up under "sound, video, and game controllers"?
thanks for the time...
-jk*
me.  Try
> this:
Device
> Manager.
you
Driver.
then
through
shoudl show
> Hope that helps!
> rEalm
> the device to USB.
PC
may
complains
> it's "unknown".
> detected.
> thanx
> -jk*
2003-06-21 by Phine Brother
not working for me either. says "specified location does not contain
info on your hardware" for 0 and 1.
will try win2k on another machine tonite. will keep posted
me.  Try
> this:
> Device
> Manager.
and you
Driver.
then
through
shoudl show
> Hope that helps!
> rEalm
> the device to USB.
PC
may
complains
> it's "unknown".
> detected.
> thanx
> -jk*
2003-06-22 by steve_the_composer
contain
After some unstable usb access having to do with a failed driver
installation and reinstallation (Win98SE), I went back to ground
level 0.  I THINK I went into Device Manager, removed the drivers,
removed the unpacked e-loader/driver software, rebooted without the
usb hookup, unzipped the software again, and did everything over
again step-by-step (triple checking everything as I went along).
I decided the 1st installation didn't take for some reason; the
second one without undoing what the first installation did gave the
illusion of taking--hence the unpredictable results; and the need to
return to scratch set things right.
I believe someone else on this board or another board mentions a
similar process for XP.
Hope this helps.
