Re: [xl7] REPEAT in LIST
2001-12-03 by erik_magrini@Baxter.com
Gotcha! I was trying doing it slightly out of order. I would press Repeat, then try to scroll to the new event to make my changes. I thought the whole "not having two events at thr same location" thing took effect when you left Pattern Edit mode, oops! I knew I should have read the addendum again! Oh well, you know how it is when you're deep into making a new track... Thanx again Aaron! rEalm Bottom line? Press repeat, edit the event, increment. Repeat, edit, increment.
