XX-7 EQ Clarification
2003-07-01 by erik_magrini@Baxter.com
Well, yes and no.  The XX-7's don't have EQ per se, but because an EQ is
really nothing more than a filter, you can approximate the same effect via
the filter for each Preset (Patch in XL-7 speak).  So if you wanted to
remove some of the lowend for a sound, you could use a high-pass filter,
etc.
Just think of the filter cutoff as the EQ frequency, and the resonance as
the amount of boost.  Roughly speaking :)
rEalm
I remember some discussion bout eq - can one adjust the eq individually
for each patch?
