Re: [xl7] I have a buzz in my headphones
2003-07-16 by Zay-Ah
same issue just came up out of nowhere.... havent figured it out yet.. --- augsun2000 <patosun@...> wrote: > any idea how to get rid of it > it is not on the outputs only when I use the headphones > > __________________________________ Do you Yahoo!? SBC Yahoo! DSL - Now only $29.95 per month! http://sbc.yahoo.com
2003-07-16 by [Mowah]
A search in the list archive will help. :) Zay-Ah wrote: > same issue just came up out of nowhere.... > havent figured it out yet.. -- Sebastien, -=-=-=-=-= Wanted: Volcano. Average size. Must be active.
i had done that and recieved no hits... i'll try again.. this time with less vodka.. ;) --- "[Mowah]" <poumtschak@...> wrote: > A search in the list archive will help. :) > > Zay-Ah wrote: > > same issue just came up out of nowhere.... > > havent figured it out yet.. > -- > Sebastien, > -=-=-=-=-= > Wanted: Volcano. Average size. Must be active. > __________________________________ Do you Yahoo!? SBC Yahoo! DSL - Now only $29.95 per month! http://sbc.yahoo.com
2003-07-17 by M2
Make sure that the 8 screws that hold the unit together on the bottom are tight. That was a cause for concern at one time. --- In xl7@yahoogroups.com, Zay-Ah <zay_ah@y...> wrote: > i had done that and recieved no hits... i'll try again.. this time with less vodka.. ;)
> > --- "[Mowah]" <poumtschak@f...> wrote: > > A search in the list archive will help. :) > > > > Zay-Ah wrote: > > > same issue just came up out of nowhere.... > > > havent figured it out yet.. > > -- > > Sebastien, > > -=-=-=-=-= > > Wanted: Volcano. Average size. Must be active. > > > > > __________________________________ > Do you Yahoo!? > SBC Yahoo! DSL - Now only $29.95 per month! > http://sbc.yahoo.com
2003-07-17 by tcdave
I have the same problem with my XL7...buzz sounds...and you no I noticed that the sound of the buzz changes when you scroll the tempo/pattern/barbeat/track button... tcdave --- In xl7@yahoogroups.com, "M2" <mmcquay@s...> wrote: > Make sure that the 8 screws that hold the unit together on the > bottom are tight. > > That was a cause for concern at one time. > > > --- In xl7@yahoogroups.com, Zay-Ah <zay_ah@y...> wrote: > > i had done that and recieved no hits... i'll try again.. this time
> with less vodka.. ;) > > > > --- "[Mowah]" <poumtschak@f...> wrote: > > > A search in the list archive will help. :) > > > > > > Zay-Ah wrote: > > > > same issue just came up out of nowhere.... > > > > havent figured it out yet.. > > > -- > > > Sebastien, > > > -=-=-=-=-= > > > Wanted: Volcano. Average size. Must be active. > > > > > > > > > __________________________________ > > Do you Yahoo!? > > SBC Yahoo! DSL - Now only $29.95 per month! > > http://sbc.yahoo.com
2003-07-17 by augsun2000
-Yea that is just what mine does -- In xl7@yahoogroups.com, "tcdave" <davedude_92692@y...> wrote:
> I have the same problem with my XL7...buzz sounds...and you no I > noticed that the sound of the buzz changes when you scroll the > tempo/pattern/barbeat/track button... > > tcdave > > > > > --- In xl7@yahoogroups.com, "M2" <mmcquay@s...> wrote: > > Make sure that the 8 screws that hold the unit together on the > > bottom are tight. > > > > That was a cause for concern at one time. > > > > > > --- In xl7@yahoogroups.com, Zay-Ah <zay_ah@y...> wrote: > > > i had done that and recieved no hits... i'll try again.. this > time > > with less vodka.. ;) > > > > > > --- "[Mowah]" <poumtschak@f...> wrote: > > > > A search in the list archive will help. :) > > > > > > > > Zay-Ah wrote: > > > > > same issue just came up out of nowhere.... > > > > > havent figured it out yet.. > > > > -- > > > > Sebastien, > > > > -=-=-=-=-= > > > > Wanted: Volcano. Average size. Must be active. > > > > > > > > > > > > > __________________________________ > > > Do you Yahoo!? > > > SBC Yahoo! DSL - Now only $29.95 per month! > > > http://sbc.yahoo.com
2003-07-17 by erik_magrini@Baxter.com
Check the FAQ, a whole section on this.
rEalm
07/16/2003 01:53 PM
Please respond to xl7
To: xl7@yahoogroups.com
cc: Subject: [xl7] I have a buzz in my headphones any idea how to get rid of it it is not on the outputs only when I use the headphones To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ [Non-text portions of this message have been removed]
