XL Edit Reasoning?
XL Edit Reasoning?
2001-12-07 by erik_magrini@Baxter.com
Quick question.  I was working on the XL-7 last night and everytime I went
to edit the track I was working on, I noticed something.  The parameters
in the Edit Pattern menus don't always default to the current track you're
working on.  A fact I noticed only after losing some valuable sequencer
data that I had overwritten, oops!  So, what's the reasoning for how the
XL/MP's assign which track is active wheny ou press Pattern Edit?  Is it
the last track you worked on?  The last track active when you saved the
pattern?  I couldn't see a pattern (no pun intended) in how it was dloing
this.
I found it funny that you effectively be accidentally editing 3 different
tracks depending on whether you were in Pattern mode, Preset Edit mode, or
Pattern Edit mode!  Isn't there someway to tie these all together so that
whatever track is the current one in Pattern mode, is also the one that is
active in Preset Edit, and Pattern Edit modes too?
rEalm
Re: XL Edit Reasoning?
2001-12-08 by novem777us
i noticed also that when if you are in pattern mode | and don't check
to see what track you are in when you are tweeking in preset  mode
what seemed like a tweek on track 2 really was done on track 1.... ..
 and even heard data leekage on another track(s) for some reason..
late.
Re: [xl7] Re: XL Edit Reasoning?
2001-12-10 by erik_magrini@Baxter.com
Yeah I figured out you can't change tracks while in Preset View mode, it
only changes the assigned MIDI channel.
Early,
rEalm
