Passive Attenuators w/ 200e...
2008-10-05 by derwskee
Want to create some passive attenuators to scale CV's to inputs where there is no input attenuation. Can you put some pots in a box hooking CV IN to the input of a potentiometer and CV OUT to the wiper without having a common ground to the 200e? I tried this with a pair of banana cables, alligator clips and some pots and some values seemed to work (unmarked pots unfortunately). Any suggestions on using LOG vs. LIN and best values for this kind of thing? Also, is there some place to tap into the common ground (tap off one of the 1/8" audio grounds or something better? Thanks for any ideas / help. Andrew
