200e
Re: Thoughts on the 260e
2005-11-20 by wiardmodular
I was disappointed in the 260e.   It did some interesting things but
it had some design choices which I didn't understand.   First why
would the 260e have a pop everytime it made a cycle on continuous
mode?  This killed the illusion for me.   I asked Don about it but
didn't really follow his reasoning.   I mean the whole point of a
sheppard tone generator should be to make a sheppard tone and a
sheppard tone with a pop every cycle is not convincing.   Maybe it was
a bug on mine?  Anyone else notice this?
The second thing I missed was a 1v/oct cv input.  The cv in with the
attenuator set fully open and a 1v/oct source plugged into it only
covered a small portion of 1 octave.  So it really needed something on
the order of 3v/oct to play a full octave.  To me I thought this would
be most interesting, playing something across that octave and having
the notes appear to constantly rise.   Despite many efforts at gaining
the 1v/oct source to match the voltage required by the 260e to do this
I was not able to get a convincing tuning.   I think it could have
been made simpler for the user by having the attenuated cv in at fully
open respond to 1 v/oct (1.2v/oct to match the rest of the buchla 200e
system).   I mean you could always attenuate the signal to cover less
than 1 octave if you wanted that.
On the plus side it did some nifty wierd things when you plugged the
gate out into an envelope and the outputs into a vca or filter and
used the pulses to do constantly rising falling bleeps.  The eq on it
was very pleasing as well.
Anyway I found it a one trick pony that couldn't do its trick very
well.  There is a review of the original 260 on the barberpole yahoo
group which doesn't mention any of the troubles I had with mine. Maybe
mine was broken or not calibrated correctly?   I don't know, I
exchanged it for a second 292e.
> Hi All
> How are people finding the duophonic pitch class generator?  In the
> keyboard magazine review it was pretty much dismissed without any
real
> info "If the 260e wasn't included in the system few musicians would
> miss it".  Anyone here disagree?
2005-11-20 by Stewart Moroney
Hi All
keyboard magazine review it was pretty much dismissed without any real
Stewart
___________________________________________________________
WIN ONE OF THREE YAHOO! VESPAS - Enter now! - http://uk.cars.yahoo.com/features/competitions/vespa.html
Maybe it was
> I've not noticed this with two that I've worked with.
Hrm interesting,  the keyboard magazine 200e review mentions a similar
issue on theirs to what I was experiencing so maybe some of the 260e
modules are buggy?   It doesn't make sense to include a continuous
mode if it pops every cycle.
260e Duophonic Pitch Class Generator
If the 260e weren't included in the system, few musicians would miss
it. Its purpose is to produce Shepard tones, an acoustic illusion of a
tone that rises or falls forever. The module can do this in either
stepped or continuous fashion, but in continuous mode it glitches,
which rather destroys the illusion.
Re: [200e] Thoughts on the 260e
2005-11-20 by Peter Grenader
Stewart Moroney wrote:
> Hi All
This is a very cool module...but, a one trick pony.  It does what it's
supposed to do really well, but how often are you going to want barber pole
type frequency patterns?  The only short comings (IMHO) is the barber
control function was not brought to the faceplate so it can be used as an
external VC for anything else.  It is instead internally 'hardwired' to the
two digital VCOs.  That's where the one trick part comes in.
Now, the two internal digital VCOs,  replete with their internal harmonic
sculpting (the five band EQ) sound really great.  They can be externally
frequency controlled (with the barber function turned off), so they can act
as auxiliary oscillators, but their VC range is only +/- 1 octave.  This
isn't an error - remember these were designed for complimenting a barber
poll algorithm and when you think about it, that's what you need for the
continual 'spiral'. That's the way Don approached it anyway.
It is was me buying, unless I had a surplus of panel space and caysh ($),
I'd pass on this guy and put the 255 in it's slot.  But that's me.
- P
The 255, instead of the 256e?
Re: [200e] Re: Thoughts on the 260e
The cv in with the   attenuator set fully open and a 1v/oct source plugged
into it only
Tempered keyboard tracking you mean?  Yeah, that would makes sense. As you
mention, the Buchla is not a 1v/oct machine, more on the order of about
1.2(ish) volts per octave - and that's on any module he's made. But having
the ability to track a keyboard (no matter what voltage is required to do
that) when the attenuator is locked into a certain position (like full CW
for instance) is a sold concern. If the inputs on the 260 aren't scaled as
such that's really weird, especially cause the faceplate graphics for the
internal barber pole addresses standard western semitones in its
nomenclature. hmmm...
>> Hi All
> real
Shit - i meant a 256.  my bad.  the 255 is fine, but i wouldn't ever need 8
slews.
Thats what I thought.  I'm moving towards getting a 256e for stage 2 of
my 200e (I'm only 1/2 filling a cabinet to start with).  Creating
complex modulations from feeding the output of 1 of the 256e sections
into another sounds like it could have lots.
> need 8
>  slews.
