My 259e seems quieter than my 261e at certain settings/FM, but then other
settings it seems about as loud as the 261e. Both the 261e and 259e seem
quieter than the 258v. I thought it was just me too, but most the odd
things, I chalk them up to Buchla quirks since most don't seem paralyzing
and have some sort of workaround.
On Mon, Sep 20, 2010 at 1:39 PM, Rash <rashemirashim@yahoo.com> wrote:
> Hi Don
> Yes, that is what was happening yesterday. Inspired by Tom's advice (thanks
> by the way Tom), I just had a session, and I seem to have isolated the
> phenomena as being linked to the Modulation Oscillator.
> That said, the Twisted hardware is behaving the same way! So perhaps this
> is just a quirk.
> Anyway if you're curious, here is what I am doing: mod type set to Morph,
> morph set to 5, tables set anywhere between 2 and 5 and setting the Mod Osc
> to say 220 and on high range. Now as I turn the Mod Osc's FM in (sans patch
> cord), I can sometimes hear changes, but looking at the green and red LED's
> either side of 'morph' reveals some definite changes as the FM in pot is
> rotated. And when this happens, it seems to occasionally have a knock on
> mirror effect on the Principal Oscillator's FM in knob.
> Being 'green' to the 200e, I am probably making a glaring omission of some
> kind. Sadly despite the reset, the volume level on the Complex seems way
> lower than the Complex. I suppose I could ask B&A about that, though I run
> the risk of being tagged a pedant!
> Cheers
> Rash
> Sent from my iPhone
> On 20 Sep 2010, at 09:05 PM, don hassler <dlh30039@yahoo.com<dlh30039%40yahoo.com>>
> wrote:
> > Are you saying on your complex, with nothing plugged in the external fm,
> you get
> > changes in frequency as you rotate the pot?
> > ________________________________
> > From: Rash Rahim <rashemirashim@yahoo.com <rashemirashim%40yahoo.com>>
> > To: 200e@yahoogroups.com <200e%40yahoogroups.com>
> > Sent: Monday, September 20, 2010 7:18:44
> > Subject: Re: [200e] 259e: Complex vs. Twisted versions gain / volume
> differences
> > Just a supplemental note about this, yesterday I performed a couple of
> side by
> > side tests, first doing an A - B comparison of the pure sine coming out
> of the
> > principal sections - there was a whisker between them if that - virtually
> the
> > same loudness. It was the same comparing the modulation oscillator in the
> > audible ranges. So my (lay) deduction is that despite the electronic
> > architecture being largely based on the same topologies, the
> implementation in
> > each version of 259e is a little different. It could be down to changes /
> > substitutions in component types. If true, I welcome the difference,
> really I
> > posed the original question for fear the Complex version I have might be
> a
> > little sick or something.
> > On the related point, I noticed that at certain settings, the FM input
> pots on
> > both the Principal and Modulation oscillators on the Complex 259e affects
> pitch.
> > With identical settings, the Twisted 259e version does not do this. For
> context
> > both modules are running v15 hardware. Sorry for the almost diary entry
> nature
> > of this post, it might be of interest to some of you.
> > Cheers,
> > Rash
> > [Non-text portions of this message have been removed]
