200e
[200e] grounding issues?
2011-08-17 by zweitesystem
Bonjour everybody,
I recently noticed the following, I don't know if it was like this before and I wanted to ask if someone here has experienced the same, and if I should worry or if that's normal behaviour...
- when an audio cable is plugged in an input, e.g., into the 291e, and the other plug (the tip) touches an edge of an output jack, the signal is interrupted;
- when a banana cable coming out of the 266e quantized output touches a screw holding a module, the output LED lights up.
Isn't that odd?
Thanks for your attention and kind regards from Geneva,
Gianluca
Re: [200e] grounding issues?
2011-08-17 by Giorgio Sancristoforo
It happened to me. That's normal, I guess that ground is on case.
On 17/ago/2011, at 05:01, "zweitesystem" <242.solaris@gmail.com> wrote:
> Bonjour everybody,
> Isn't that odd?
> Gianluca
2011-08-17 by 242.solaris
2011/8/17 Giorgio Sancristoforo <Tobor@gleetchplug.com>
> Sent from my iPad
Ciao Giorgio,
thanks for the reply.
So both things happened to you, au.sig cut + CV weirdness?
I wonder *how* the ground passes through the case, if that's
desirable and, if not, how to fix it...
G
> > Bonjour everybody,
> interrupted;
> > Isn't that odd?
> > Gianluca
2011-08-17 by jon schatz
hi,
the quiet ground runs through all the aluminum front panels with audio jacks (and possibly neighboring modules depending on how closely the panels fit). this isn't a bug or malfunction as far as i know.
thanks,
-jon
Re: grounding issues?
2011-08-22 by zweitesystem
Thank you everybody for the answer so far.
So I shouldn't worry about this...
Kind regards,
Gianluca
> hi,
> thanks,
> -jon
