200e
Additional 256e question
2006-04-28 by mritenburg
Thanks for all the previous info!  I am curious if the 256e can do
simple inverting?
Re: inverting
2006-04-28 by reedofuncertainty
I should clarify. The 256e will invert scaling, but I guess that's not
really the same thing as if you turn the input knob counterclockwise
on a 255 or an oscillator CV input. If you set the little dots on the
256e so the first one is all the way up and the last is all the way
down, an input voltage of 0V (or nothing) will yield 10V on the
output, and the higher the voltage you put in, the lower the output
voltage will go.
