Control Voltage Ranges
2007-05-08 by Richard Lainhart
All: I have a 200e system on order, for which I am waiting patiently, and plan to use my Continuum, created by Lippold Haken, as the main controller for the system. While waiting, I've been testing Lippold's new Continuum Voltage Convertor, or CVC, which is designed to convert the MIDI output from the Continuum to individual patchable control voltage outputs for use with analog synthesizers: http://www.hakenaudio.com/Continuum/html/accessories/CVC.html Lippold has designed a few presets for several of the control voltage standards currently in use, including the common 1 volt/octave, 0-10+ volts scheme and the Moog Voyager's peculiar .935 volt/octave standard. Lippold is very interested in providing a preset for the 200e, and has asked me about its control voltage standards. I don't have one, of course, and the 200e article on Wikipedia seems a little incomplete concerning control voltage ranges. From the article, it appears that the 200e's standard is 1.2 v/octave, with a range of roughly 0-10+ volts. Can anyone tell me if that's correct - that the voltage range is positive only, and 0-10+ only, or does the 200e support negative voltages or a wider control voltage range? Lippold and I thank you for any help you can provide. -- Richard Lainhart O-Town Media rlainhart@otownmedia.com http://www.otownmedia.com
