50g group photo
50g
principal value of ARG(z) of a complex number z
2008-10-22 by Simone
Why HP 50g uses this definition of principal value of ARG(z) of a
complex number z: (ARG(z=x+y*i)-> ATAN(y/x)+(1-x/ABS(x))*pi/2?
-pi<principal value of ARG(z)<=pi ->
http://en.wikipedia.org/wiki/Complex_number#Polar_form
Ex. ARG(-1-1*i)=(5/4)*pi instead of -(3/4)*pi
Greetings,
Simone.
Re: [50g] principal value of ARG(z) of a complex number z
2008-10-24 by Don Hart
I don't know why they decided not to nomalize the result in a symbolic. Maybe they thought it was only important for numeric results.
You can get the result you expect if you first enter (-1,-1) and then do ARG. You'll get a numeric which you can convert to the desired symbolic with an XQ or a ->Q(pi) operation.
You also can use XQ to convert (-1,-1) to the symbolic '-1+i*(-1)' and ->num to convert that back to (-1,-1), or actually, (-1.,-1.).
Bottom line, if you're going to be nitpicky about the form of the result, you'll have to do a little more work on it.
--- On Wed, 10/22/08, Simone <gems_tux@...> wrote:
> From: Simone <gems_tux@...>
> Subject: [50g] principal value of ARG(z) of a complex number z
> To: 50g@yahoogroups.com
> Date: Wednesday, October 22, 2008, 2:33 AM
> of a
> Greetings,
> Simone.
50g programs
2008-10-24 by Fortunate Chidzonga
can anyone amongst you HP50g users help me improve the programs i have attached hereto, especially the Rational method- it does have some looping problems because of the WHILE function i used
Re: [50g] 50g programs
2008-10-26 by Don Hart
I can't promise I'll have the time to look at your code, but I suggest that anyone who posts code should also attach the binary to the message. Anything to make life easier for those who would help is always aappreciated.
--- On Fri, 10/24/08, Fortunate Chidzonga <cfortuh@...> wrote:
> From: Fortunate Chidzonga <cfortuh@...>
> Subject: [50g] 50g programs
> Date: Friday, October 24, 2008, 4:30 AM
2008-10-28 by Fortunate Chidzonga
hie i have attached the HP50g program files that are on my memory card. i hope these are the Binary files as requested by Don Hart. your assistance in improving the programs will be greatly appreciated
