50g group photo
50g
RE: [50g]
RE: [50g]
2008-11-13 by cfortuh@yahoo.com
Can anyone please help me improve the programs i have attached here. - original message - Subject:	[50g] Re: rpn code example on hp50g computer/calculator
RE: [50g]
2008-11-20 by Don Hart
Ok, check out the attached program. I did a couple of small changes to Rational.
I eliminated everything up to the WHILE and put in a   2 'C' STO. That forces it to execute the WHILE loop and reduces the size of the program.
The only problem I could see with the WHILE loop, as you mentioned before, is that you couldn't exit using the CANCEL so I added a C PURGE and a HALT in the IF ELSE part. I didn't check the rest of the program for the same problem with CANCEL, I'll leave that up to you.
Also, you had "PLEASE CHECK" "C/R" +. Since you have a constant string, you could just do "PLEASE CHECKC/R" and eliminate the +.
I hope that helps.
--- On Wed, 11/12/08, cfortuh@... <cfortuh@...> wrote:
> From: cfortuh@... <cfortuh@...>
> Subject: RE: [50g]
> To: 50g@yahoogroups.com
> Date: Wednesday, November 12, 2008, 8:40 PM
> attached here.
Re: [50g]
2008-11-21 by Don Hart
I should have used KILL not HALT. Sorry
eliminate the +.
> I hope that helps.
> > Subject: RE: [50g]
> > attached here.
