how long to wait for FREEZE to come high?
2004-03-10 by Aaron J. Grier
I've got a 68331CFC25 in a circuit. we've been shuffling debugging duties between machines, and having some gremlins appear. the current device driver we use for BDM does bit-banging to an ICD32 pod. one of the oddities we've been seeing shows a BDM request being made without the FREEZE line coming up. since the FREEZE line doesn't come up, the driver assumes the system isn't in background mode, and tries again. usually this second BDM request works and things continue on as usual. however, occationally the situation arises where even after this second try the FREEZE line still remains low, and the BDM device driver throws up its hands. (of course after hooking up the logic analyzer the gremlins haven't shown up, but that's the way it goes...) how long should we be waiting for FREEZE to come up after attempting to get into BDM mode? the 68331 is running a 32kHz crystal, so before the PLL is programmed, it's running at 8MHz, correct? we have a 1k pullup on RESET\ line. currently the device driver is waiting ~15ms for FREEZE to come up after pulling BKPT\ low and pulling RESET\ low (we are seeing the CPU pull it back up high). -- Aaron J. Grier | Frye Electronics, Tigard, OR | aaron@...
