Index last updated: 2026-04-29 00:01 UTC
Proper way to acknowledge a PIT interrupt
2007-03-13 by andreichichak
Hi All Y'All,
In trying to track down a niggly bug on my '332, I came across a
question...
You typically have to acknowledge an interrupt somehow, by clearing a
bit or reading a register. How do you acknowledge the PIT (Periodic
Interrupt Timer in the SIM) interrupt?
Andrei
Re: [68300] Proper way to acknowledge a PIT interrupt
2007-03-14 by Scott Newell
My code doesn't.  Checked the SIM book and the SIM section in the
'360 book; neither mentions any ack requirement.
newell  N5TNL
Re: Proper way to acknowledge a PIT interrupt
2007-03-14 by andreichichak
Thanks Scott,
I thought it was rather odd that it doesn't need an ack.
Have all of the Freescale people left the building?
Andrei
> newell  N5TNL
Re: [68300] Re: Proper way to acknowledge a PIT interrupt
2007-03-14 by twalter@austin.rr.com
PIT just does it thing!
SXSW (south by southwest) Festival this week, as is Spring Break in the
Austin,TX
area.  http://2007.sxsw.com/
Where's Charlie (Melear)?  Haven't heard from him in ages.
Tom Walter
Date: Wednesday, March 14, 2007 12:00 pm
Subject: [68300] Re: Proper way to acknowledge a PIT interrupt
To: 68300@yahoogroups.com
> Thanks Scott,
> Andrei
> the
> > newell  N5TNL
2007-03-20 by jeffrey.tenney@gm.com
Andrei,
Did you find the bug yet?  If not have you seen the errata about having an
external device using the same interrupt level as the PIT?  Could that be
your problem?
(Sorry I don't have a reference for you.)
Jeff
"andreichichak" <groups@...>
Sent by: 68300@yahoogroups.com
03/12/2007 09:11 PM
Please respond to
To
cc
Subject
Hi All Y'All,
question...
Andrei
2007-03-20 by Andrei Chichak
Hi Jeff (and everybody else)
>Andrei,
No, I didn't.
The possible issue with the PIT interrupt seems to have been teaser.
As we have seen from the various responses, it does not seem like you
have to do anything to acknowledge the PIT.
The problem that I was trying to track down was actually with the
TPU. When using the UART function, I would occasionally see a
doubling of the input characters and a mass retransmission of my
output buffers by my interrupt routines. After much head scratching
and searching I deduced that the interrupt routines were occasionally
triggered twice for a single event (I was getting two interrupts for
a single transmitter empty event, and two interrupts for a single
character received event). I really didn't expect to see an issue as
I only had 12 half UARTs running at 300 baud, one half UART running
at 9600 baud, two DIOs, and one PWM that was turned off.
I had never seen anything like this before, but I am using a new
compiler (GCC), and running at 4MHz instead of 16MHz, so the low
level routines for my OS (uC/OS-II) had to be reworked.
I eventually ran across an app note for the TPU UART that mentioned
the position of the interrupt clear instructions with respect to the
accessing of the data buffers, and how you CAN get doubling of interrupts.
After much head scratching and experimentation, I bolstered other
pieces of the system to be able to detect and throw away packets that
have the corrupted data.
>your problem?
No, I don't think so. I'll look for the errata sheet though. I'm not
using any external interrupts and the PIT is the only device assigned
to its interrupt level.
>Jeff
Thanks for your help,
Andrei
