The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
Help needed! An1x and An1xEdit
2002-02-06 by jomany2002
Hi all!
I'm new to this group as well as to An1x.
I've been trying to send patches to the synth from An1xEdit with
little success. I have read the manual as well as the help files in
An1xEdit but there must be something I don't get. Sending a whole
soundset ends up with a sysex error and just a few patches are
uploaded.
I would appreciate if someone could find some time to explain exactly
how to upload the content of  .an1 files into my An1x.
Cheers
///jomany
Re: Help needed! An1x and An1xEdit
What happends is that i get a sysex size error when transfering the
patches. I just tried the London soundset and some of the patches
didn't transfer due to this..
I seem to get most of them though, maybe I should settle with that.
When sending data around the three LED's are flashing a bit. Is this
normal or does it indicate a problem?
Cheers
///jomany
--- In AN1x-list@y..., "jomany2002" <totte@n...> wrote:
> Hi all!
in
> uploaded.
exactly
> Cheers
> ///jomany
2002-02-06 by jondl_2000
patches
that.
From your two problem reports I'd hazard a guess that your MIDI
Interface is suspect :-/ What type of MIDI Interface are you using?
FWIW, AN1x SysEx data is sizable and the AN1x can be overrun
when receiving a bulk dump. This is not uncommon but the fact
that you're having such difficulties so frequently might indicate a
problem with your MIDI Interface.
I'd suggest you try sending a 1/3 of a voice set at a time, i.e.,
voices 1-32, then 33-64,etc., simply to determine whether they'll
tranfer reliably. Also, many soundsets - user sound sets,
specifically - normally contain fewer voices then the Yamaha
voice sets. Since there is less data to transfer it stand to reason
there would be fewer overrun errors. Perhaps you should try a
few along the same lines - to determine how prone your MIDI
Interface is to bottlenecking.
Is this
It's normal...and it sounds as though you're using the program
correctly based on the fact that the transfer is occuring.
Hope this helps,
Jon
2002-02-07 by jomany2002
Crappy midi port it was.
Thanks for your help.
///jomany
> the
> patches
> that.
a
reason
> Is this
> Hope this helps,
> Jon
