The Yamaha AN1x Synthesizer mailing list group photo
Index last updated: 2026-04-28 22:40 UTC
an200 v's an150 test
2003-01-03 by DMANX@talk21.com
Hi all,
I have spent the whole day messing around with the AN/DX200 desktop synths.The DX200 sounds much better,excellent user seq voices. The AN200 can do everything th AN150 can do and a little more e.g krap techno drum seq, krap effects and good varible morph/scene 1-2 control,better factory sound/user voices,real time knob control.But the voices can be used on the an150 if somone is prepared to up load them.The drums and effects are very basic well not to cool.You can use up to 4 voices, by coping scene1 to 2, then create an new voice for scene 1this is is all played back as a step sequence.Then on top of that you can play normally via a another selected voice on your midi keyboard.....cool.
However,My conclusion is that, the drums and effects are not worth it,its just a cheep techno groove box for DJ'S,but  the morph/scene control is good.If you use an150 with reaktor drums/seq+VST effects you get better standard and quality.It just lacks scene control and better morphing?And access to AN200 sound banks?
I would like to here from anyone else whom have tested this units.
Regards Dmanx
talk21 your FREE portable and private address on the net at http://www.talk21.com
Re: [AN1x] an200 v's an150 test
2003-01-04 by Mark Pipher
I just wanted to add, to dispel any "myths" in past discussion, the AN200
really IS a PLG150AN in a box. I was bored the other night, so I took the
bottom off, and there it was - the PLG150AN card mounted nicely right under
the cover. It's identical to the PLG card I have. I wasn't daring enough to
detach it and plug it into my CS6x, but it would definitely work.
Your assessment does seem correct, the units are identical with the
exception of morph/scene control and the factory "sounds" and sequences.
I prefer the knobby interface of the AN200, FAR easier to edit and create,
without having to use a computer, or deal with the limited parameters and
display of the "host" synth.
Mark
On 1/3/03 11:56 AM, "DMANX@..." <DMANX@...> wrote:
> Hi all,
> keyboard.....cool.
> sound banks?
> Regards Dmanx
