--- In AN1x-list@yahoogroups.com, "megasycophant"
<megasycophant@y...> wrote:
> I just recently picked up a secondhand AN1x, my first. Two of the
> knobs don't respond to the second push, the one that shows which
> parameter is being modified. Is this a common failing for these?
> Is it indicative of a larger problem?
> Thanx for any help...
Speaking for myself, I've not had this problem with the Assign Knobs
on my AN1x - which is now 5+ years old.
I suspect either 1) you've experienced an inevitable problem with the
AN1x resulting from regular wear & tear many of us have yet to
encounter - or - 2) the previous owner applied too much force when
using the encoders and wore thru them prematurely.
It would be interesting to hear from anybody else on the list who
might have run into the same situation as you.
I've no doubt a certified Yamaha service center can replace the
failed encoders on the PCB board. I'd be surprised to find an AN1x
covered under warranty at this late date so be prepared to pay for
parts & labor - typcial costs of ownership.
Hope this helps.
Jon
