Re: [AN1x] Volume levels to the max on keyboard or mixer? Or neither?
2004-01-05 by kaltar
Well, I Think That It Depends On The Synth And Setup. There Are no Rules, Just Like In The Kitchen. Just What You Want To Achieve. First, It's Supposed That The Hotter The Signal, The Better. You Can Lower that On The Mixer Or On The DAW. Having A Hotter Signal Allows You To "Minimize" the Noise. This Is The Principle You Should Work On. Try To Listen The Sound Of The People Walking While Standing In Front Of The Speakers In A Dance Club. You Can't, Cause The Signal (Music) to Noise (Shoes Noise) Ratio Is Very Extreme. So The Idea Is Keep The Difference As Big As You Can, So The Noise Is Not Listened. (unless You Have A Synth With Digital Output Or A Softsynth). And When You Mix It, And Lower The Volumes (On Your Mixer or DAW) You Are Lowering The Noise Too, So The Ratio Keeps There. Some Synths Have A Low S/N Ratio, Hence Maxing Its Main Volume Will Max The Noise. In That Case, Put Your Mixer Fader On 0db And Lower The Volume On Your Synth Until You Hear No Noise, But The Synth Sounds Level Are Ok. Here Also The Output Signal Level Of The Synth Plays Great Part. This Way You Can Reach A Good Level (Like Peaking -6db) Or A Bad One (-30db Is Bad Enough For You?). For Every Synth Is Different. Play With This For Getting The Less Noise And The More Signal. Also, Some Clean Sounding Synths Can Distort While The Volume Is Too Loud. So Lower The SYNTH Volume Until It Sounds Ok... Now, The Mixing Is On The Mixer, Not On The Synths Volume Knobs! Other Topic Is The Synth MIDI Channel Volume. And That Is A Personal Taste! (It Will Escalate with 128 steps. So For Mixing Most People Would Go The MIXER Way). Some People Claim That The Midi Volume Actually Alters Sometimes The Performance. That Is Deppending The Synth, Of Course, And, Again, Your Taste.
