Re: [AVR-Chat] Fuses: Permanently disable spi/isp
2007-10-23 by dlc@frii.com
However, if you disable the SPI then you have done so permanently if all that you have is an AVR ISP or ISPII. You'll need a STK500 and a soldering iron to get it back. DLC
> On Tue, 23 Oct 2007 16:32:33 +0200 (CEST) > "Manne Tallmarken" <mannet@kth.se> wrote: >> Is it possible to permanently disable all kinds of >> read/write operations to the flash? >> >> Regards, >> >> Manne >> > > I don't believe that you can, PERMANENTLY. If the device > can be parallel programmed, the fuses can be over-ridden by > erasing the flash (or something like that). Also, devices > with SPM operation can write to flash, I believe, if it is > run from the proper code space no matter what the fuses are > set to. > > That is my understanding of such things. > > Jim Wagner > Oregon Research Electronics, Consulting Division > Tangent, OR, USA > --------------------------------------------------------------- > The Think Different Store > http://www.thinkdifferentstore.com/ > For All Your Mac Gear > --------------------------------------------------------------- > > > > Yahoo! Groups Links > > > >
