AVR-Chat
INTO interrupt firing all the time?
2007-12-17 by Richard Cooke
Hi Folks,
I'll try this question again as my post of Dec 15th didn't receive any
replies.
What would cause the INT0 to continually fire even if the pin was
grounded?  I have the set to trigger on rising edge (MCUCR = 0x03) but
it will keep triggering.  I have also tried to set it to "any logical
change" (MCUCR = 0x01) but get the same results.
Anybody have any ideas why a pin that is grounded would trigger an
interrupt?
Richard Cooke
Re: INTO interrupt firing all the time?
Hi Zack,
I've grounded it after not being able to figure out why it keeps
firing.  I figured that if it was grounded it couldn't be a hardware
issue.  I grounded it via a very short wire.
Richard
--- In AVR-Chat@yahoogroups.com, Zack Widup <w9sz@...> wrote:
> Hi Richard,
> My first thought is that if it's grounded, why are you setting it up
for
> use in firmware? Why not just disable it?
> How is it grounded?  Do you have a long circuit trace or wire to ground
> that might be picking up crosstalk from other nearby lines? Is it
> "grounded" through another circuit such as a TTL or CMOS chip?
> Zack
> On Mon, 17 Dec 2007, Richard Cooke wrote:
> > Hi Folks,
> > replies.
> > interrupt?
> > Thanks,
> > Richard Cooke
Re: [AVR-Chat] INTO interrupt firing all the time?
2007-12-17 by Zack Widup
Hi Richard,
My first thought is that if it's grounded, why are you setting it up for
Zack
> Hi Folks,
> replies.
> interrupt?
> Thanks,
> Richard Cooke
