AVR-Chat
Re: INTO interrupt firing all the time?
2007-12-17 by Richard Cooke
This is why it is so frustrating.  I just re-measured the ground
connection and according to my ohmmeter it is indeed grounded.
And using the debugger it stops on the interrupt:
"interrupt (EXT_INT0) void ext_int0_isr(void)"  The ATtiny.h file
lists EXT_INT0 as = 2 which is what the datasheet shows.
BTW I'm using the CodeVisionAVR C Compiler.
Richard Cooke
--- In AVR-Chat@yahoogroups.com, "Dennis Clark" <dlc@...> wrote:
>   It can't fire if it is grounded.  If it IS firing then one of your
> assumptions is incorrect:
> A- You are actually attached to ground
> B- That INT0 is actually what is firing
>   So, disable the interrupt and see if the problem goes away - If it
does
> then assumption A needs to be examined.  If it does not then clearly
> assumption B needs to be examined.
> DLC
Re: [AVR-Chat] Re: INTO interrupt firing all the time?
2007-12-17 by Dennis Clark
  So, disable the interrupt and see if the problem goes away - If it does
DLC
> Hi Zack,
> I've grounded it after not being able to figure out why it keeps
> firing.  I figured that if it was grounded it couldn't be a hardware
> issue.  I grounded it via a very short wire.
> Thanks,
> Richard
> --- In AVR-Chat@yahoogroups.com, Zack Widup <w9sz@...> wrote:
>> Hi Richard,
>> My first thought is that if it's grounded, why are you setting it up
> for
>> use in firmware? Why not just disable it?
>> How is it grounded?  Do you have a long circuit trace or wire to ground
>> that might be picking up crosstalk from other nearby lines? Is it
>> "grounded" through another circuit such as a TTL or CMOS chip?
>> Zack
>> On Mon, 17 Dec 2007, Richard Cooke wrote:
>> > Hi Folks,
>> > I'll try this question again as my post of Dec 15th didn't receive any
>> > replies.
>> > What would cause the INT0 to continually fire even if the pin was
>> > grounded?  I have the set to trigger on rising edge (MCUCR = 0x03) but
>> > it will keep triggering.  I have also tried to set it to "any logical
>> > change" (MCUCR = 0x01) but get the same results.
>> > Anybody have any ideas why a pin that is grounded would trigger an
>> > interrupt?
>> > Thanks,
>> > Richard Cooke
Dennis Clark
TTT Enterprises
