AVR-Chat
I/O line protection
I/O line protection
2008-01-03 by Steven Hodge
My apologies ahead of time for the length of this post, but I realize it
would be hard to answer without adequately describing the operating
environment.
I'd like to get feedback on ideas I have to provide protection for I/O lines
for uC-based PCB's.  These will be scattered throughout a boat, so 12 V DC
(up to 14.6 V when the main "house" batteries are on charge) is the nominal
supply voltage -- call it VB -- for all boards.  There is lots of this
running around everywhere, not just to PCB's but to motors, pumps, diesel
engine, solenoid coils, radios, radar, instruments, stereo, computer, etc.
All grounds come back to a single common ground bus near the house battery
bank.
Protection concerns are (1) overvoltage on an I/O pin by accidentally
connecting it to VB, (2) the usual ESD, (3) protection of the uC and digital
stuff from RF-induced voltages from the radar and VHF & HF radios (and who
knows what else, eg, computer), and (4) protection in the opposite
direction, of the radar/radios from RF noise from digital switching.
Usually an inverter is also in use, to supply "household" 120 VAC from the
12 V house bank, so that probably adds to the noise.
All the uC-based boards will be linked with an RS485 bus, using shielded
CAT-5 Ethernet cable and LTC1480 transceivers at each end.  These
transceivers include ESD protection.
The uC will be an ATmega644P running at 3.0 - 3.3 V (still undecided) and
1.8432 MHz (for ideal RS485 and lower power consumption).  The power supply
will be an LP2951.  The Atmel App Note AVR042 gives a pretty good
description of how to protect the uC power pins, so I'm following the
recommendations there (although I did have to clarify the units in Fig 6-1
with Atmel tech support).  I'll also put the usual bypass capacitor at the
pins of all other IC's.  At this point, I don't have any questions about
power protection, and this post is just directed at I/O pins.
There is no high-frequency I/O requirement.  Almost all digital signals
change state once in a blue moon on uC time scales.  At most I might have
one at 50 Hz max, and 1 or 2 at a few Hz.  All analog signals are very
slowly varying, time scales of tens of seconds at the fastest.
PCB real-estate is a bit of an issue but not a serious one.  At any rate,
I'd like to start with what is functionally the best and only then adjust if
the result makes the boards unacceptably too big.
All I/O signal wires will be shielded, with the shield grounded only at one
end.
I always attempt to have input signals active-low, floating when not
asserted (and pulled high at the PCB end), but there are still many cases
where active-high is unavoidable.  Signal levels are either CMOS or VB level
in most cases.  There are a few at 5 V level.
As much as possible I'll try to use a ground plane on the uC-based PCB's,
but probably not a power (Vcc) plane.
For digital input lines, I'm proposing:
(a) front end protection using a MAX681x for mechanical switch input (which
the majority of input signals are) or a Littelfuse SP72x for non-switch
inputs.  Both have ESD & overvoltage protection. The MAX681x has the
additional advantage of providing automatic high-to-low level shifting to
get VB-level signals down to CMOS levels, and thus, since the 50 ms time
delay of this IC is not an issue in most cases, I could just use it
everywhere except for those cases where it would be an issue (eg, the 50 Hz
signal).  The trade-off is that if I used the SP72x there would be a
significant number of situations where I would have to add a high-to-low
buffer/shifter IC.
(b) an additional RC low-pass filter between the above and the uC pin, where
the value of R is chosen so it also acts to limit the current into the uC
pin to its max of 40 mA.  C would then be selected so the -3dB breakpoint of
the filter is well above 50 Hz, say 1-2 KHz.  Values I've computed, for
CMOS-level voltages, are about 100 ohms for R and about 1 uF for C for such
a breakpoint.
For analog input lines, level-shifting cannot be done so I'd just use the
SP72x and RC filter.  The filter values would be adjusted to accommodate
their typically higher voltages (such as VB or 5 V).
When it comes to output lines, things are murkier in my brain.  For signal
and non-inductive load outputs, I'm thinking of using the same SP72x's, or
nothing at all.  Inductive loads will definitely require a flyback
suppression diode, but it's not clear to me if I should also add the SP72x,
or a DO-15 package TVS, to them as well.  I often also install a diode
across the actual load (ie, actual motor or solenoid coil terminals).
Any comments on any of the above will be very appreciated.   One specific
question I have is should I add anything else to the RS485 lines, beyond
what the LTC1480 transceivers provide?
Thanks, Steve
Re: [AVR-Chat] I/O line protection
2008-01-03 by James Wagner
> realize it
> environment.
> O lines
> V DC
> nominal
> diesel
> computer, etc.
> battery
> bank.
> digital
> (and who
> from the
> shielded
> undecided) and
> supply
> Fig 6-1
> at the
> about
> have
> rate,
> adjust if
> at one
> end.
> cases
> VB level
> PCB's,
> (which
> switch
> shifting to
> time
> the 50 Hz
> low
> buffer/shifter IC.
> pin, where
> the uC
> breakpoint of
> for such
> a breakpoint.
> use the
> accommodate
> signal
> SP72x's, or
> SP72x,
> specific
> beyond
> Thanks, Steve
> Steve -
> What you do depends on the "mission-critical" nature of the
> application. If this  is what it seems, then too much might not be
> too much. Generally, the ESD-protected RS485 transceivers are pretty
> good. I've put those through rigorous transient tests needed for
> European CE compliance, and they are fine.  Depending on what your
> outputs do and what they might be exposed to, opto-couplers might be
> in order. But, those only break ground loops and provide isolation,
> they don't provide any over-voltage protection. I am a fan of diodes
> and self-resetting fuses for low speed applications. Raychem and
> others make the fuses; look at DiodesInc for the diodes. In that
> kind of app with good series self-reset fuses, 600W diodes (sma
> series, for example)  should be good and they don't cost an arm and
> a leg.  For what its worth,
> Jim Wagner
> Oregon Research Electronics
> Tangent, OR, USA
Re: I/O line protection
2008-01-04 by Bruno
Hi Steven.
About the I/O lines, i've never heard about the littlefuse. Didn't
you think to use optocouplers? Like the TIL111.
About the RS-485, you could put some passives components plus the
LTC1480 transceivers. On the magazine, Circuit Cellar, the october
issue an article cames talking about the subject of protection RS-
485. If you want i could provide more information for you.
Bruno
--- In AVR-Chat@yahoogroups.com, "Steven Hodge" <stevehodge@...>
realize it
> environment.
I/O lines
12 V DC
the nominal
this
diesel
computer, etc.
battery
> bank.
accidentally
and digital
(and who
switching.
from the
shielded
undecided) and
power supply
Fig 6-1
capacitor at the
about
signals
might have
very
any rate,
adjust if
only at one
> end.
not
many cases
or VB level
PCB's,
input (which
switch
shifting to
ms time
the 50 Hz
a
to-low
> buffer/shifter IC.
pin, where
the uC
breakpoint of
computed, for
for such
> a breakpoint.
use the
accommodate
For signal
SP72x's, or
the SP72x,
diode
terminals).
specific
beyond
> Thanks, Steve
Re: [AVR-Chat] Re: I/O line protection
2008-01-04 by Philippe Habib
You want to think in layers of protection.  Diodes or surge
protectors, then gas discharge tubes for the really big zaps.  One
issue I've run into is that as the isolation provided by optocouplers
increases, they get way slower.  I've had to bit bang some SPI
interfaces down at the kilohertz because the optocouplers were so slow.
Do you have standard that you have to meet in terms of voltage and
duration?  That makes it a lot easier to figure out just how much you
need to do.
On Jan 4, 2008, at 2:41 AM, Bruno wrote:
> Hi Steven.
> Bruno
> realize it
>> environment.
> I/O lines
> 12 V DC
> the nominal
> this
> diesel
> computer, etc.
> battery
>> bank.
> accidentally
> and digital
> (and who
> switching.
> from the
> shielded
> undecided) and
> power supply
> the
> Fig 6-1
> capacitor at the
> about
> signals
> might have
> very
> any rate,
> adjust if
> only at one
>> end.
> not
> many cases
> or VB level
> PCB's,
> input (which
> switch
> the
> shifting to
> ms time
> the 50 Hz
> a
> to-low
>> buffer/shifter IC.
> pin, where
> the uC
> breakpoint of
> computed, for
> for such
>> a breakpoint.
> use the
> accommodate
> For signal
> SP72x's, or
> the SP72x,
> diode
> terminals).
> specific
> beyond
>> Thanks, Steve
RE: [AVR-Chat] Re: I/O line protection
2008-01-06 by Steven Hodge
Thanks for the various thoughts.  I'm pursuing various leads people have
given me.  One lead I'm not pursuing, however, is optocouplers simply
because of the power needed to run them (one optocoupler can easily be the
same or more than the uC).
I have the Circuit Cellar article on order (unfortunately I subscribed a
month too late to get it free).
I don't have any "standards" I'm trying to meet.  I just want things to work
as reliably as I can reasonably make them.
Steve
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Philippe Habib
Sent: Friday, January 04, 2008 9:24 AM
To: AVR-Chat@yahoogroups.com
Subject: Re: [AVR-Chat] Re: I/O line protection
need to do.
> Hi Steven.
> Bruno
> --- In AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com> ,
> realize it
>> environment.
> I/O lines
> 12 V DC
> the nominal
> this
> diesel
> computer, etc.
> battery
>> bank.
> accidentally
> and digital
> (and who
> switching.
> from the
> shielded
> undecided) and
> power supply
> the
> Fig 6-1
> capacitor at the
> about
> signals
> might have
> very
> any rate,
> adjust if
> only at one
>> end.
> not
> many cases
> or VB level
> PCB's,
> input (which
> switch
> the
> shifting to
> ms time
> the 50 Hz
> a
> to-low
>> buffer/shifter IC.
> pin, where
> the uC
> breakpoint of
> computed, for
> for such
>> a breakpoint.
> use the
> accommodate
> For signal
> SP72x's, or
> the SP72x,
> diode
> terminals).
> specific
> beyond
>> Thanks, Steve
__________ NOD32 2765 (20080104) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
2008-01-07 by John
Are you referring to using the optos as input buffers or output
drivers?  Not all optos are created equally.
I use MCT9001 type optos - a simple diode input and an open collector
output.  The power consumption is a function of input and output
impedences, with the MCT9001 (or similar footprint devices) ranging in
transfer ration from 50% to 200%.  Thus, if I have a 100K input
resistor with a 12V input, I will consume 0.12 mA on the 12V side,
this will transfer over to (at least) 0.06 mA on the uC side. I can
use the uC input's pull-ups (around 100K,) thus on the uC side, the
opto uses 0.05 mA.
I don't consider this to be excessive current draw.
Unless you need high speed outputs, use a relay to isolate the output.
 Higher speed outputs can utilize the opto to drive an open collector
transistor/fet.  The opto part of the circuit in this instance will
still consume little current (enough to turn on the transistor/fet.)
John
be the
to work
> Steve
Behalf
> Of Philippe Habib
> need to do.
> > Hi Steven.
> > Bruno
> "Steven Hodge" <stevehodge@>
> > realize it
> >> environment.
> > I/O lines
> > 12 V DC
> > the nominal
> > this
> > diesel
> > computer, etc.
> > battery
> >> bank.
> > accidentally
> > and digital
> > (and who
> > switching.
> > from the
> > shielded
> > undecided) and
> > power supply
> > the
> > Fig 6-1
> > capacitor at the
> > about
> > signals
> > might have
> > very
> > any rate,
> > adjust if
> > only at one
> >> end.
> > not
> > many cases
> > or VB level
> > PCB's,
> > input (which
> > switch
> > the
> > shifting to
> > ms time
> > the 50 Hz
> > a
> > to-low
> >> buffer/shifter IC.
> > pin, where
> > the uC
> > breakpoint of
> > computed, for
> > for such
> >> a breakpoint.
> > use the
> > accommodate
> > For signal
> > SP72x's, or
> > the SP72x,
> > diode
> > terminals).
> > specific
> > beyond
> >> Thanks, Steve
> > Yahoo! Groups Links
> http://www.eset.com
