AVR-Chat
Ecros Ice Cube / AVR RISP MKII / Butterfly clarification
2008-01-08 by k5atm
I am new to the world of Atmel chips.  I am a long time PIC
programmer looking to expand my horizons.
I purchased a Butterfly with a specific project in mind but I am a
bit confused and looking through the archives did not help much. I am
using AVR Studio 4.13 and WinAVR.
I would like to avoid using the bootloader to load my code.  I am
using the RS232 port and swaping cables every time I want to load
code is a pain.
As far as I can tell I cannot use the AVR RISP to program the
Butterfly.  Apparently the RISP cannot detect if the host (Butterfly)
has power -- a feature to protect the Butterfly's battery?  Since I
already have a (USB) RSIP MKII I was wondering if I can safely fake
out the RSIP and make it think the host has power?  Would a
Butterfly / Butterfly carrier / RSIP combo work?
I am also a bit confused on JTAG debuggers.  It appears that a
Butterfly / Butterfly carrier / Ecros Ice Cube combo will work just
fine.  Will a Butterfly connected directly to an Ice Cube work? -- or
do I need to provide external power to the Butterfly for the Ice Cube
to work.
Thanks in advance for any help on such a basic question.
-Mike
Re: [AVR-Chat] Ecros Ice Cube / AVR RISP MKII / Butterfly clarification
2008-01-08 by John Samperi
If you have an AVRISP MK2, the REAL Atmel unit, ISP should
work provided that the Butterfly's battery is in good condition.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Re: Ecros Ice Cube / AVR RISP MKII / Butterfly clarification
2008-01-08 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "k5atm" <k5atm@...> wrote:
> I purchased a Butterfly ... am a
> bit confused ... the RISP cannot
> has power ...
The Butterfly does not provide power at the ISP connector.  Yes, this
is to protect the Butterfly's battery, which can only supply a few
milliamps.
> I already have a (USB) RSIP MKII ...
If this does not take power from the ISP connector, it should work.
It probably senses power (drawing only a tiny current), so you will
have to link power from the Butterfly to pin 2, maybe via a resistor.
> host has power?
You must apply the same voltage as is powering the target because
this voltage is used to set the signal drive levels of the programmer.
> Would a Butterfly / Butterfly carrier
> / RSIP combo work?
Yes.  This is exactly what the Butterfly Carrier is designed to do.
> ... a Butterfly / Butterfly carrier
> fine.
Again, yes, this is what the Butterfly Carrier is designed to do.
> an Ice Cube work?
No on this one.  The AVR ICE-Cube takes its power from the target and
needs 10 to 20 mA.  The AVR Butterfly battery cannot supply this, so
pin 7 of the JTAG header is unconnected and the AVR ICE-Cube won't
light up.  If you buy an ICE-Cube, you might as well buy the
Butterfly Carrier too, it will solve a lot of problems.  If you don't
want to buy the carrier, you could use an external power source to
fire up the ICE-Cube (negative at ground, 3 volts at pin 7 of the
JTAG header).  But, be sure to supply a voltage within 0.5 volts of
the battery voltage.  The AVR ICE-Cube has current limit resistors on
all signals, so you won't permanently mess anything up if you go
wrong, but it may not work.  It would probably be better to power
both the AVR Butterfly and the ICE-Cube from external power, which is
what the Butterfly Carrier does.
Graham.
Full disclosure - I am ECROS Technology
