AVR-Chat
serial communication
2008-02-05 by bhadson2001
i am recieving data serialy from PC to atmega16. i am recieving data
of four byte frame in avr.then i am setting the avr's ports according
to data recieved in USART RXC interrupt routine. i is working fine at
the starting. but after sometime it is mulfunctioning. what should i
do to resolve the problem.
                    can any body give me its solution.
kindly help me, if you can or if you have any other
idea................
              thanks a lot for it..........
Re: [AVR-Chat] serial communication
2008-02-05 by Kathy Quinlan
You do not provide enough information to help solve the problem, so I
will be general:
#1 you could have a problem with your stack
#2 you could be trashing your buffer
#3 you could have a corrupted data byte that is stopping your Rx routine
from working....
#4 you could be ending up in an endless loop....
If you can post your code we can look over it.
Kat.
2008-02-05 by BobGardner@aol.com
You dont know if the problem is in the communication or the data is messing up the port. So write a serial test that sends a known data packet, and have the receiver check for correct reception. This test confirms that serial comms work (or dont work).
To: AVR-Chat@yahoogroups.com
Sent: Tue, 5 Feb 2008 5:26 am
Subject: [AVR-Chat] serial communication
Yahoo! Groups Links
________________________________________________________________________
More new features than ever.  Check out the new AOL Mail ! - http://webmail.aol.com
2008-02-05 by Zack Widup
If it works at first but then quits, I can't help but think you're doing
something like resetting some of the USART parameters later on in your
program or rewriting over something you have stored in memory.
Take a look and see if you're changing something like that later on.
Zack
2008-02-05 by Dennis Clark
For starters you could show us your code.
DLC
Dennis Clark
TTT Enterprises
2008-02-05 by David VanHorn
This is a part of the art that isn't taught much..
How to diagnose or debug a problem.
Basically, you need to divide up your system, to know that "THIS PART
WORKS", and keep sectioning off the problem into a smaller and smaller
space until you have it cornered.
I learned this art in analog electronics, how to divide up the system
and isolate the problem. The approach works just as well with
software, and with microcontrollers it's not all that unusual to have
problems that are both in hardware and in software.
"drive a stake in the gound" with some part of your code that outputs
something you can see, and be absolutely sure that it always works.
Use that to debug other parts of the system.
And then there is what I have taught my students and preach a bit about
on the 'net.  It comes in part from Sherlock Holmes and part from my own
experience:
Data Watson!  Data!  You cannot make bricks without straw.
and
If the data does not make any sense, examine your assumptions, at least
one of them is incorrect.
DLC
Dennis Clark
TTT Enterprises
2008-02-05 by Roy E. Burrage
To add to this, building your program as a set of modules makes this
process a lot easier.  Your main program would be a series of calls to
subroutines that would return to the main program when they're done
doing what ever it is they do.  Doing a flow chart helps in this
process.  It takes a little more time up front, and forces us to put
some forethought into what our program is going to do in the beginning,
but saves time in the long run.
Of course, there are always those who hate to document...
REB
Too quick with the send button...
If your main program is nothing but a series of calls to subroutines,
you can divide and conquer by commenting out a particular subroutine
during test in order to see if that's where your problem is.  This also
allows for easier simulation and test in that you can test individual
modules independently of the rest of the program.
It's always easier to beat a critter into submission a little at a time
than to take everything on all at once.  Those of us with simple minds
must find simple solutions.  But this, too has been learned in an analog
world...block out a system, break all of those blocks into smaller and
simpler blocks.  The system is nothing more than a set of simple
circuits put together to form a complex function...bricks used to build
a wall.
REB
>REB
2008-02-05 by John Samperi
My GUESS is #5 Using the internal clock.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Problem with getting signal
2008-02-14 by khahramon0786
Hi All. Look at my source code, i couldn't find my fault there.
I want to get 40Khz, but in VMLAB it shows 29Khz.here is my source code.
This program was produced by the
CodeWizardAVR V1.24.8b Professional
Automatic Program Generator
© Copyright 1998-2006 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date    : 13.02.2008
Author  : Khahramon
Company : TUIT
Comments:
Chip type           : ATmega16
Program type        : Application
Clock frequency     : 4,000000 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
#include <mega16.h>
#define xtal 4000000
#define hz 40000
interrupt [TIM1_OVF] void timer1_ovf_isr(void)
// i need 40Khz signal in PORTA.0, that's way i took 80kHz interrupt
TCNT1=0x10000-(xtal/1/(2*hz));
PORTA.0^=0x01;
void main(void)
PORTA=0x00;
DDRA=0x01;
TCCR1A=0x00;
TCCR1B=0x01;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x04;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
while (1)
Can you help me where's my mistake
Re: [AVR-Chat] Problem with getting signal
2008-02-14 by John Samperi
Is your clock REALLY 4MHz? Have you set the necessary fuses?
John Samperi
2008-02-15 by Khahramon Nuriddinov
yes, i'm sure about that! I'm sending you my CodeVersionAVR , VMLAB and Proteus project version!
John Samperi <samperi@ampertronics.com.au> wrote:                               At 03:11 PM 14/02/2008, you wrote:
 John Samperi
 Send instant messages to your online friends http://uk.messenger.yahoo.com
Re: Problem with getting signal
2008-02-15 by Stefan Wimmer
--- In AVR-Chat@yahoogroups.com, "khahramon0786" <khahramon0786@...>
Shouldn't that be  TCNT1=0x10000-(xtal/(1/(2*hz))); ??
2008-02-16 by John Samperi
And what am I supposed to do with that? Sorry for asking silly
questions.......
John Samperi
