AVR-Chat
how to avoid data loss in wireless using avr
2008-02-15 by bhadson2001
i am recieving data from serial port of PC to AVR. sometimes
controller recieve data different. i am using 4 byte frame to
recognize a particular command. sometimes it picks up different
command. what will i do to solve the problem.
         kindly help me.
Re: [AVR-Chat] how to avoid data loss in wireless using avr
2008-02-16 by David Kelly
1) get a better radio link.
2) build in error checking on your data packets
3) investigate redundant and self-correcting codes
4) all of the above
Of course, "all of the above" is what wireless is all about.
Otherwise it would be too easy and everyone would think they could do
it.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2008-02-16 by James Wagner
You can also do an acknowledge and retry. Error checking only tells
you that the received data is bad.
One scheme goes like this....
1. Sender transmits data block (packet) with CRC or checksum
2. Receiver checks CRC or checksum. If OK, it sends a short "ACK"
message back. If bad, it sends a "NACK" (not ACK) message. ACK and
NACK are defined by you.
3. Sender retransmits the message if a NACK is received.
4. If NEITHER ACK nor ACK is received in a certain time, it sends the
original again.
5. There is usually a MaximumRetry value after which the sender gives
up.
Jim
> 4) all of the above
> it.
2008-02-16 by Tom Becker
> ... 1) get a better radio link.
Do I misunderstand that Bluetooth will not deliver received data that
has not been validated?  A few years ago we did some simple range
testing with several Bluetooth radios.  At a distance that was greater
than the expected range, a packet was handed to each transmitter and the
radio was walked toward the receiver until the packet appeared at the
receiver output.  Each time, as I recall, the correct data was
eventually produced.
Is not Bluetooth "error free" if it is communicating at all?
Tom
2008-02-16 by dlc
What are you using?  I've used Bluetooth and XBee and neither have ever
given me bad data (no data at all when out of range though.)
DLC
>          kindly help me.
Dennis Clark          TTT Enterprises
www.techtoystoday.com
> ever
The OP sounded like a school assignment (typical plea for help with
no details as to how anything is being done) so I gave a broad all-
encompassing generic answer.
Bluetooth, Zigbee, and 802.15.4 are much higher level communication
protocols than the OP's "4 byte command packet." We have no idea
whether he has a bidirectional interface. We know he doesn't have
error detection other than the device behaves wrong when the wrong
data is received. So we are pretty confident in guessing he doesn't
have error correction.
Suggested reading: http://en.wikipedia.org/wiki/
Forward_error_correction and http://en.wikipedia.org/wiki/
Error_correction
> and the
A problem with Bluetooth is that it has tried to be everything to
everyone, and got so bloated no one without a huge budget can afford
its overhead.
Based on my readings several years ago Bluetooth has accurate
delivery methods for what you describe above but also has guaranteed-
rate delivery which sacrifices data integrity. Drop a few bits in
your Bluetooth headset and the last thing you want is for them to be
delivered accurate but late. You'd rather just drop them and move on.
