AVR-Chat
Mega16 PWM
Mega16 PWM
2008-02-24 by J C
I am trying to control 2 servos with an ATMEGA16 running off of an 8MHz crystal. I have tried to figure it out with various code examples on the internet but don't seem to be getting it. Here is my code, any ideas?
#include <avr/io.h>
#define F_CPU        8000000
// Set for Prescaler of 8 at 8MHz xtl = 1us
#define Timer1ON()   TCCR1B|=0x0D
#define Timer1OFF()  TCCR1B&=0xF7
int main(void)
    Timer1OFF(); // stop timer 1
    // Set for PWM (Table 47, mode 10 page 112
    // of Mega16 datasheet)
    TCCR1A = _BV(COM1A1) | _BV(COM1B1) | _BV(WGM11);
    TCCR1B = _BV(WGM13);
    // 20000 * 1us = 20ms or 50Hz
    ICR1 = 20000;
    // set the port pin and direction
    DDRD |= 0x30;
    PORTD &= (0xFF ^ 0x20);
    Timer1ON();
    while(1)
        OCR1A = 1500;
        OCR1B = 1500;
Looking for last minute shopping deals?  Find them fast with Yahoo! Search.
Re: [AVR-Chat] Mega16 PWM
2008-02-25 by David VanHorn
What I do, is to set up an array of bytes in memory, each holding a
0-255 value for pulse width.
I add this to a minimum pulse width, and create timer values.
I start all the servo pulses at once, then turn them off at the
appropriate time using a single timer interrupt.
So the output looks like
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
and so on.
Then the framing pulse (15mS or so) is just a do-nothing time.
2008-02-28 by J C
Thanks for that idea, I did get the other code running but the clock wasn't set right so I wasn't seeing any pulses. I might try that idea in the future.
David VanHorn <microbrix@gmail.com> wrote:                               On Sun, Feb 24, 2008 at 5:52 PM, J C <stereotyperjack@yahoo.com> wrote:
 and so on.
