AVR-Chat
Another C-ish question
2009-03-24 by David VanHorn
I frequently end up using a bunch of timers in a 1mS ISR, that are
decremented to zero by the ISR, and set by some other task.
The code would end up looking like this:
if (0 < Timer1) Timer1--;
if (0 < Timer2) Timer2--;
and so on.
Is there a more efficient way to handle those?
Generally they will be living in SRAM, but I wouldn't rule out them
living in registers for small apps.
There is no computer problem which cannot be solved by proper
application of a sufficiently large hammer.
Re: [AVR-Chat] Another C-ish question
2009-03-25 by David Kelly
> and so on.
I write same thing, but differently. Guessing the compiler generates
the same code as you have written:
if( timer1 )
	timer1--;
if( timer2 )
	timer2--;
Have seen others write this way but I'm certain its slower unless you
don't know in advance how many timers are needed:
for( i = 0 ; i < number_of_active_timers ; i++ )
	if( timer[i] )
		timer[i]--;
When I need a coarser but longer running timer:
if( timer_100ms && (--internal_timer_100ms == 0) ) {
	timer_100ms--;
	internal_timer_100ms = 100;
The "if" is evalated left to right and stops once the expression must
be true or false. Perhaps clearer to write this way which should
generate exactly the same code:
if( timer_100ms ) {
	if( --internal_timer_100ms == 0 ) {
		timer_100ms--;
When timer_100ms reaches 0 then internal_timer_100ms should be 100,
initialized for the next use.
But more often I need to count off minutes or seconds, so I make an
internal timer that counts down to seconds, and then place my
software seconds timers in that group, Perhaps I need minutes as well
so I put another internal timer counting 60 seconds before handling
my minutes timers.
It looks like it takes a lot of time. Perhaps it does if one must
count in ms resolution.
If one needs fine resolution consider running a hardware timer with a
divisor and count interrupts on overflow. When your event occurs you
can read the hardware timer and the software overflow interrupt
counter to know the time very precisely.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
