AVR-Chat
16f88 vref problem
16f88 vref problem
2009-08-05 by Yingdan
Hello,
I am using VREF+ and AVss for a potentiometer. Below is my setting:
status_rp = 01   	-- select bank 1
CVRCON = 0b_1110_0110
ANSEL  = 0b_0001_1001
ADCON1 = 0b_0010_0000	-- VREF+/AVSS
status_rp = 00		-- select bank 0
The VREF+ pin gives ~1.2v and I can get the reading 0 - 255 in the range of 0 - ~1.2v. The problem is the reading is unstable. When I rotate the shaft from high to low, and low to high, I got different readings for a specific position. From high to low, I got a relative bigger reading and from low to high, I got a much smaller reading for the similar position.
I have no idea how to fix the problem. Can anyone help to take a look at my CVRCON and ADCON1 registers since I am not confident with them, or offer any help about what might be wrong?
Your help is highly appreciated,
Yingdan
Re: [AVR-Chat] 16f88 vref problem
2009-08-05 by John Samperi
Ask at microchip.com NOT here, this is an Atmel AVR forum.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
2009-08-05 by Jim Wagner
This is an AVR group, not PIC. You can try one of the PIC lists for
better help.
Jim Wagner
On Aug 4, 2009, at 7:41 PM, Yingdan wrote:
> Hello,
> Yingdan
2009-08-05 by Dao Viet Dung
Why don't you try ATMEGA8.
--- On Wed, 8/5/09, Yingdan <yingdanh@gmail.com> wrote:
Subject: [AVR-Chat] 16f88 vref problem
To: AVR-Chat@yahoogroups.com
Date: Wednesday, August 5, 2009, 9:41 AM
                  Hello,
Yingdan
2009-08-05 by enkitec@gmail.com
I don't believe you are still using these PIC toys.   :-) :-) :-)
Yingdan wrote:
> Hello,
> Yingdan
2009-08-05 by Harkfin Balrog
Depending upon your source, the internal A/D capacitors retain a certain
amount of the voltages you are sampling. Try sampling a grounded signal
(or the internal ground) before sampling your POT.
Yingdan wrote:
> Hello,
> Yingdan
> __._,_.__
