AVR-Chat
A couple of 168p questions
2009-12-18 by Philippe Habib
I'm using a 168p on a project and I've run into a couple of things
that I want to make sure I got right from the data sheet.
The first is using the ADC7 pin as an output.  Can that be done?  My
compiler tells me the required defines are not there and all I see in
the datasheet is about the pin being an ADC input pin.  Is that pin
input only?
The other is when I use the PCINT pins.  Is there a way to tell which
of the pins triggered the int or do I have to keep track of the pins
state and compare it myself?  Again, I didn't see a register that I
can just look at with that information..
I'd love to hear that I missed both of these things.
Thanks.
Re: [AVR-Chat] A couple of 168p questions
2009-12-18 by Jim Wagner
> input only?
> Thanks.
On the PCInts, yes, you have to track them back if you have more than
one in any bank of interrupts.
ADC inputs are also general purpose I/O pins. Checkj the alternate
function section of the data sheet for details. For minimum ADC noise,
you don't want to change an output pin while the ADC  is running.
Jim Wagner
Oregon Research Electronics
2009-12-18 by John Samperi
...except for the M168 family... :-)
ADC6 and ADC7 are only available for the TQFP
or MLF packages and are inputs ONLY.
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Thank you for the replies.  In both cases, that's what my reading of
the datasheet led me think.  I was just hoping I was wrong and had
overlooked something.
> Regards
> John Samperi
