AVR-Chat
AVRISP -> AtTiny Communication Problem
2010-01-15 by Kenny M
Sorry this post is a bit long.
I'm new to all this so be gentle LOL :)
I'm working on my first project, which I've built and is working.
All that's missing is the chip to control it.
I've got a few AtTiny15's and an AVR-ISP v2 (usb)
So built a target board and connected all the programmer pins to the appropriate pins on the chip.
I also connected my 5V+/Gnd to the chip.
Now this is where I get confused,
I've found so many different schematics on the net...
1) This one just says connect everything as above and program
2) Run a 4.7kohm between reset and vcc.
3) Run a 4.7kohm & 10uf between reset and vcc.
4) Run a 4.7kohm & 22pf between reset and vcc.
5) Run a 4.7kohm & 10uf between reset and vcc, and an 800ohm resistor to all the other connections.
I've only tried 1 and 2, since I don't have the caps I'm trying to figure out what I need before I head to the store.
Right now AVR Studio does see something, because it can read/write the speed of the unit. But everything else is just says an error occured.
I'd appreciate any help.
Kenny
Re: [AVR-Chat] AVRISP -> AtTiny Communication Problem
2010-01-16 by H. Carl Ott
> Unless you have some serious noise problems you don't need any cap on
reset.
You may or may not need a resistor to vcc ( I have to check the data sheet),
but a 10k resistor will work, and will not cause any problems.
 4.7k should also work, but the value is a little low for ISP.
Check your ISP programming speed in studio.  It must be less the 1/4 your
AVR's clock speed.
 And double check all your connections. It always seems tricky getting this
stuff to work the first time. After a while it gets easier (well,
mostly/usually/hopefully).
> __._,_.__
carl
Henry Carl Ott   N2RVQ    hcarlott@gmail.com
2010-01-16 by John Samperi
So you think I wouldn't see this? I'm everywhere. :-)
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
