AVR-Chat
Re: [AVR-Chat] AVRISP -> AtTiny Communication Problem
2010-01-17 by Kenny M.
I'll hook everything back up and swap out that resistor for a 10k in the morning.
Hopefully that does it, I'll let you know how it goes
I appreciate your help with this guys.
And me thinking this would be the easy part lol :p
-Kenny
To: "AVR-Chat" <AVR-Chat@yahoogroups.com>
Sent: Saturday, January 16, 2010 11:39:22 AM GMT -05:00 US/Canada Eastern
Subject: Re: [AVR-Chat] AVRISP -> AtTiny Communication Problem
On Fri, Jan 15, 2010 at 2:09 PM, Kenny M < kenny782@yahoo.com > wrote:
> Sorry this post is a bit long.
> I'm new to all this so be gentle LOL :)
> I'm working on my first project, which I've built and is working.
> All that's missing is the chip to control it.
> I've got a few AtTiny15's and an AVR-ISP v2 (usb)
> So built a target board and connected all the programmer pins to the
> appropriate pins on the chip.
> I also connected my 5V+/Gnd to the chip.
> Now this is where I get confused,
> I've found so many different schematics on the net...
> 1) This one just says connect everything as above and program
> 2) Run a 4.7kohm between reset and vcc.
> 3) Run a 4.7kohm & 10uf between reset and vcc.
> 4) Run a 4.7kohm & 22pf between reset and vcc.
> 5) Run a 4.7kohm & 10uf between reset and vcc, and an 800ohm resistor to
> all the other connections.
> Unless you have some serious noise problems you don't need any cap on
reset.
You may or may not need a resistor to vcc ( I have to check the data sheet),
but a 10k resistor will work, and will not cause any problems.
4.7k should also work, but the value is a little low for ISP.
Check your ISP programming speed in studio. It must be less the 1/4 your
AVR's clock speed.
And double check all your connections. It always seems tricky getting this
stuff to work the first time. After a while it gets easier (well,
mostly/usually/hopefully).
> __._,_.__
carl
Henry Carl Ott N2RVQ hcarlott@gmail.com
