AVR-Chat
Re: [AVR-Chat] UPDATE - AtTiny Communication Problem
2010-02-07 by Kenny M.
Well new wire, nice short runs, 100nf ceramic cap added from 5v+ to gnd
God is this aggravating, I could have had someone build 20 of these this things cheaper lol.
So I have three options for my next step.
1) Try ordering some new chip(s)
2) Order a prebuilt protoboard
3) When I mentioned it Digikey offered to exchange the the avrisp2 for a dragon
I think option 1 might be best??? based on ebay as my source on the current ones who knows if they actually work.
Any recommendations on a replacement model? Preferably one that doesn't require an external oscillator for now.
Kenny
To: AVR-Chat@yahoogroups.com
Sent: Friday, January 29, 2010 3:40:21 PM GMT -05:00 US/Canada Eastern
Subject: Re: [AVR-Chat] UPDATE - AtTiny Communication Problem
I think I might pickup some lighter wire too.
Maybe some telephone wire I think it's 26 gauge solid usually.
Sent: Thursday, January 28, 2010 11:24:57 PM GMT -05:00 US/Canada Eastern
Subject: RE: [AVR-Chat] UPDATE - AtTiny Communication Problem
Hi Kenny,
I had a quick look at your setup and frankly you'd save yourself and us quite a bit of time if you made the whole setup a bit more 'solid'. As others have said flying wires everywhere - and no bypass caps - and uncertain continuity - and uncertain connections - are all too variable for anyone to be able to help (unless they are sitting next to you)
If I were you I would -
1. Make all lead lengths as short as possible
2. Check the continuity of each line (miso,miso,sck,reset, etc) between the AVR ISP and ACTUAL pin of the micro (the proto boards are notorious for intermittent connections).
3. Check you have a nice clean 5V PSU (a regulated lab power supply is a great investment)
4. make sure you add the 100nF bypass cap as close as possible to the micro PCB.
5. Double (triple) check you connections between the ISP and the micro (MISO and MISO are easily swapped)
6. Try to get a know working board (sparkfun has some pretty cheap prebuilt kits)
I'd have for you to be discouraged for this hobby just because of a bad start but you are really having a bad time at this. Unless you have plenty of spare time I's start with something 'known working' then get back to these 'bargain' ATTinys when you have more confidence in you setup and your abilities.
Good Luck
Ivan
> From: AVR-Chat@yahoogroups.com [mailto: AVR-Chat@yahoogroups.com ] On
> Behalf Of Kenny M.
> Sent: Friday, 29 January 2010 2:33 PM
> Yes you're right, I had to reverse the connections when using the clip.
> I just didn't bother just for taking that pic.
> -Kenny
> From: "erikc" < firewevr@airmail.net >
> Sent: Thursday, January 28, 2010 10:29:30 PM GMT -05:00 US/Canada
> Eastern
> In one of those pictures you have a part in an inverted "dip-clip".
> Is that part the AVR? If so, check all the connections.
> erikc
> Kenny M. wrote:
> > Here are some pics, hopefully you can make sense of them ... lol
> > http://img163.imageshack.us/slideshow/webplayer.php?id=dsc00362oy.jpg
> > From: "John Samperi" < samperi@ampertronics.com.au >
> > Sent: Thursday, January 28, 2010 4:06:34 PM GMT -05:00 US/Canada
> Eastern
> > At 08:05 PM 28/01/2010, you wrote:
> >> Well it's got to be your board then.
> >> Either some pins wired up incorrectly between the programming header
> >> processor, or solder bridges between the programming lines.
> > ...and we still don't know if he has ANY bypass caps on the power
> supply pins.
> > Regards
> > John Samperi
Re: UPDATE - AtTiny Communication Problem
2010-02-07 by Donald H
1) god won't help you
2) If you can pay to have this built, why are you still trying to make this work on the cheap ?
This is your best option.
After you have one working, the rest will be easier.
don
> Thanks,
> Kenny
> From: "Kenny M." < kenny782@... >
> From: "Ivan Vernot" < ivernot@... >
> Hi Kenny,
> Good Luck
> Ivan
> > Behalf Of Kenny M.
> > -Kenny
> > From: "erikc" < firewevr@... >
> > Eastern
> > erikc
> > > From: "John Samperi" < samperi@... >
> > Eastern
> > supply pins.
> > > Regards
> > > John Samperi
> > Yahoo! Groups Links
