AVR-Chat
Using WatchDog messes up timings in my code (ATMega644P 20AU)
2010-03-11 by Cat C
Got this very strange problem(s).
1. For some reason, at power-up (4.5V from linear on-board regulator from PC 5V PSU) the microcontroller starts up temporarily but then stops (or goes to microcontroller heaven).  I know this because I'm sending some text on the serial port near the start of the program and I only get some of it.
If I press the reset button all is fine, so maybe strange things happen because power might go up too slow.
I decided to use the watchdog so if it doesn't get to the main loop (where it gets kicked) it will reset the board.
This seems to work, but:
2. Some timings that work fine when I don't use the watchdog now get messed up in the strangest way:
Depending on a value I set in Timer 1, I get a big change in Timer 0 (a period supposed to be about 440us is now about 3ms).
There are still things to check, but... does anybody have an idea that might save me some time?
Any help appreciated, thank you,
Cat
PS - when I enable the watchdog I'm NOT setting the fuse, just in SW:
#include <avr/wdt.h>
main()
     wdt_enable(WDTO_1S);
     while (1)
     wdt_reset ();
The timing routines are quite complex, involving setting Timer0 inside interrupt handler of Timer1, etc.
