USB to serial db9 cable
2010-02-23 by rsimonus
I am curious about USB to serial db9 cable. I am planning to buy one. I want to know if any USB to serial 9pin cable which will work with any device and my old Sony Clie or it is depend on brand and model? I see walmart sell those for $9 dollars. Reid
2010-02-23 by Leon Heller
On 23/02/2010 23:00, rsimonus wrote: > I am curious about USB to serial db9 cable. I am planning to buy one. I want to know if any USB to serial 9pin cable which will work with any device and my old Sony Clie or it is depend on brand and model? I see walmart sell those for $9 dollars. The ones with an FTDI chip usually work OK. There are some with a cheaper chip (I forget what they are called, something beginning with P?) but they often have problems. The very cheap ones like that $9 one might not work very well. Leon -- G1HSM http://webspace.webring.com/people/jl/leon_heller/
2010-02-24 by Donald H
--- In AVR-Chat@yahoogroups.com, Leon Heller <leon355@...> wrote: > > On 23/02/2010 23:00, rsimonus wrote: > > I am curious about USB to serial db9 cable. I am planning to buy one. I want to know if any USB to serial 9pin cable which will work with any device and my old Sony Clie or it is depend on brand and model? I see walmart sell those for $9 dollars. > > The ones with an FTDI chip usually work OK. There are some with a > cheaper chip (I forget what they are called, something beginning with > P?) but they often have problems. Prolific PL-2303 These have been around for a long time and work very well. One thing you have to understand, after loading the driver for the first time, the USB dongle will be assigned a serial port number by Windows. If you plug the same dongle into another USB port on the same computer, the COMx port number will change. But if you plug it back into the original USB port, the original number will be assigned. This is Windows, not the dongle. I have not found any USB-2-serial dongle that will keep the COMx number the same across USB ports. don The very cheap ones like that $9 one
> might not work very well. > > Leon > -- > G1HSM > http://webspace.webring.com/people/jl/leon_heller/ >
2010-02-24 by Philippe Habib
I've had mixed luck. Sometimes they've worked for me. Sometimes I've gotten errors depending on the device. One motor controller I was working with wouldn't work with the cable or with a PCMCIA card. I wound up having to buy a computer with built in serial port for that project. Its cheap enough to see if it would work for you.
On Feb 23, 2010, at 3:00 PM, rsimonus wrote: > I am curious about USB to serial db9 cable. I am planning to buy > one. I want to know if any USB to serial 9pin cable which will work > with any device and my old Sony Clie or it is depend on brand and > model? I see walmart sell those for $9 dollars. > > Reid > > > > ------------------------------------ > > Yahoo! Groups Links > > >
2010-02-24 by enkitec@gmail.com
> don
I would like to introduce my FTDI USB-2-serial dongle that doesn't
change the COMx number when connected on different USB port.
Don't ask me why, I don't know.
Mark Jordan2010-02-24 by STEVEN HOLDER
It depends on how the EEprom is configured, if the device is set to use a fixed serial number then it will always enumerate itself as the same com port whichever USB it is plugged into. I use these devices a fair bit and i always reconfigure the eeprom settings so that all FTDI devices (when i'm developing) will enumerate themselves as the same com port number. MPROG 3.5 can read write these settings or it can be done through the api dll. Regards --- On Wed, 24/2/10, enkitec@gmail.com <enkitec@gmail.com> wrote:
From: enkitec@gmail.com <enkitec@gmail.com> Subject: Re: [AVR-Chat] Re: USB to serial db9 cable To: AVR-Chat@yahoogroups.com Date: Wednesday, 24 February, 2010, 12:35 On 24-Feb-10 02:06, Donald H wrote: > I have not found any USB-2-serial dongle that will keep the COMx number the same across USB ports. > > don > > I would like to introduce my FTDI USB-2-serial dongle that doesn't change the COMx number when connected on different USB port. Don't ask me why, I don't know. Mark Jordan [Non-text portions of this message have been removed]
2010-02-24 by Zack Widup
Is this a commercially available device? Or one you built yourself? Either way, can you supply info on it? Zack On Wed, Feb 24, 2010 at 6:35 AM, <enkitec@gmail.com> wrote: > > > On 24-Feb-10 02:06, Donald H wrote: > > I have not found any USB-2-serial dongle that will keep the COMx number > the same across USB ports. > > > > don > > > > > > I would like to introduce my FTDI USB-2-serial dongle that doesn't > change the COMx number when connected on different USB port. > > Don't ask me why, I don't know. > > Mark Jordan > > > [Non-text portions of this message have been removed]
2010-02-24 by Marc R.J. Brevoort
On Tue, 23 Feb 2010, rsimonus wrote: > I am curious about USB to serial db9 cable. > I am planning to buy one. I want to know if > any USB to serial 9pin cable which will work > with any device and my old Sony Clie or it is > depend on brand and model? I see walmart sell > those for $9 dollars. I recently got one labeled HL-340 which works fine-it didn't need any drivers, just setting another COM port from minicom. Testing it was a bit difficult though. If you want to use a DB9-to-USB cable to communicate with a microcontroller, you need to keep in mind that the data being sent by the USART is - inverted comparted to RS232 traffic - uses TTL levels (0-5 volts) rather than RS232 levels (-12..-3, 12..3 volts) You *can* try to overcome these two problems by feeding the signals through a NOT gate and then stepping up the voltage with a charge pump. This is highly educational and if you are in it for the experience, I can highly recommend it. ... but if you simply want to communicate from AVR to PC and get it done fast, it's much easier to just order a little MAX232 converter board as well, hook up the USART pins to that and be done with it. I got something like this: http://cgi.ebay.co.uk/MAX232-RS232-Serial-to-TTL-UART-Converter-Board-Adapter_W0QQitemZ120534212314QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item1c10661eda Depending on your needs you might even simply use a TTL-to-USB rs232 interface board and skip the DB9 connector altogether: http://cgi.ebay.co.uk/USB-to-RS232-Module-Based-TTL-Converter_W0QQitemZ260550110677QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca9ff2dd5 Hope this helps. Best, Marc
2010-02-24 by dex_design
Hi! > I have not found any USB-2-serial dongle that will keep the COMx number the same across USB ports. My Prolific USB-2-serial cable does that under Win 7. Don't know about it under XP, I kind of started using it a few weeks ago.
2010-02-24 by Reid
I looked at Newegg store http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=usb+to+rs232 I could not find FTDI chip on it. There are few usb to rs232 cables. Reid On Tue, Feb 23, 2010 at 4:20 PM, Leon Heller <leon355@btinternet.com> wrote: > > > On 23/02/2010 23:00, rsimonus wrote: > > I am curious about USB to serial db9 cable. I am planning to buy one. I > want to know if any USB to serial 9pin cable which will work with any device > and my old Sony Clie or it is depend on brand and model? I see walmart sell > those for $9 dollars. > > The ones with an FTDI chip usually work OK. There are some with a > cheaper chip (I forget what they are called, something beginning with > P?) but they often have problems. The very cheap ones like that $9 one > might not work very well. > > Leon > -- > G1HSM > http://webspace.webring.com/people/jl/leon_heller/ > > > [Non-text portions of this message have been removed]
2010-02-24 by Tim McDonough
I would be interested in a solution to this as well. I have several pieces of an Arduino board that have USB and no tru serial port. Even when they are individually attached to the same USB port they do not attach to the same virtual COM port. You can go into Windows and change the port but that would be a pain in a lot of applications. It would be nice if you could tell the driver to "always use COM5" or whatever. Tim On Wednesday, February 24, 2010 8:48 AM [GMT+1=CET], Zack Widup wrote:
> Is this a commercially available device? Or one you built > yourself? Either way, can you supply info on it? > Zack > > > On Wed, Feb 24, 2010 at 6:35 AM, <enkitec@gmail.com> wrote: > >> >> >> On 24-Feb-10 02:06, Donald H wrote: >>> I have not found any USB-2-serial dongle that will keep the >>> COMx number the same across USB ports. >>> >>> don >>> >>> >> >> I would like to introduce my FTDI USB-2-serial dongle that >> doesn't change the COMx number when connected on different >> USB port. >> >> Don't ask me why, I don't know. >> >> Mark Jordan >> >> >> > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Yahoo! Groups Links > > >
It isn't a comercial device. Just an old FT232AM chip without
external EEPROM, circuit according to FTDI. Nothing special.
I can plug it on any USB port to have a COM2 on Windows.
Mark JordanOn 24-Feb-10 11:48, Zack Widup wrote: > Is this a commercially available device? Or one you built yourself? Either > way, can you supply info on it? > Zack > > > On Wed, Feb 24, 2010 at 6:35 AM,<enkitec@gmail.com> wrote: > > >> >> On 24-Feb-10 02:06, Donald H wrote: >> >>> I have not found any USB-2-serial dongle that will keep the COMx number >>> >> the same across USB ports. >> >>> don >>> >>> >>> >> I would like to introduce my FTDI USB-2-serial dongle that doesn't >> change the COMx number when connected on different USB port. >> >> Don't ask me why, I don't know. >> >> Mark Jordan >> >> >> >> > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Yahoo! Groups Links > > > > >
I have several pieces of ham radio equipment that use RS232 connections. These pieces of equipment that are commercially made were either made by companies that are no longer around or are not being produced with USB upgrades yet. And then there's some things I built myself! Zack
On Wed, Feb 24, 2010 at 10:23 AM, Tim McDonough <tmcdonough@gmail.com> wrote: > I would be interested in a solution to this as well. I have several > pieces of an Arduino board that have USB and no tru serial port. Even > when they are individually attached to the same USB port they do not > attach to the same virtual COM port. You can go into Windows and > change the port but that would be a pain in a lot of applications. It > would be nice if you could tell the driver to "always use COM5" or > whatever. > > Tim > > On Wednesday, February 24, 2010 8:48 AM [GMT+1=CET], > Zack Widup wrote: > >> Is this a commercially available device? Or one you built >> yourself? Either way, can you supply info on it? >> Zack >> >> >> On Wed, Feb 24, 2010 at 6:35 AM, <enkitec@gmail.com> wrote: >> >>> >>> >>> On 24-Feb-10 02:06, Donald H wrote: >>>> I have not found any USB-2-serial dongle that will keep the >>>> COMx number the same across USB ports. >>>> >>>> don >>>> >>>> >>> >>> I would like to introduce my FTDI USB-2-serial dongle that >>> doesn't change the COMx number when connected on different >>> USB port. >>> >>> Don't ask me why, I don't know. >>> >>> Mark Jordan >>> >>> >>> >> >> >> [Non-text portions of this message have been removed] >> >> >> >> ------------------------------------ >> >> Yahoo! Groups Links >> >> >> > > > ------------------------------------ > > Yahoo! Groups Links > > > >
2010-02-25 by Moataz Hussein
I,ve used the CP2102 it comes complete on board with output level at 5V which can be connected directly to the controller, http://www.sparkfun.com/commerce/product_info.php?products_id=198 Hope this helps, Moataz Hussein
Sent: Wednesday, February 24, 2010 4:51 PM
Subject: Re: [AVR-Chat] USB to serial db9 cable
Hope this helps.
Best,
Marc
[Non-text portions of this message have been removed]2010-02-28 by stevec
I and many others choose USB/Serial adapters that use the FTDI chipset and Windows driver. Always good and reliable, unlike so many crapola drivers from China. --- In AVR-Chat@yahoogroups.com, "dex_design" <dzoltan.listak@...> wrote:
> > Hi! > > > I have not found any USB-2-serial dongle that will keep the COMx number the same across USB ports. > > My Prolific USB-2-serial cable does that under Win 7. Don't know about it under XP, I kind of started using it a few weeks ago. >
2010-02-28 by Bob Paddock
On Wed, Feb 24, 2010 at 11:23 AM, Tim McDonough <tmcdonough@gmail.com> wrote: > Even > when they are individually attached to the same USB port they do not > attach to the same virtual COM port. You can go into Windows and > change the port but that would be a pain in a lot of applications. It > would be nice if you could tell the driver to "always use COM5" or > whatever. This should work for non-FTDI devices, just match the VID/PID. From FTDI Support: Hello, What you will need to do is uninstall the driver for the FTDI device. Now you will need to create a binary value in the registry by doing the following: Go to START and select RUN Type regedit in the filed and select ok to get into the registry Add a REG_BINARY value called IgnoreHWSerNum to the registry and setting it to 01. This value is held in the registry key located at: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\UsbFlags\IgnoreHWSerNum (Device VID, PID and interface} For a default FTDI device ID (VID 0x0403, PID 0x6001), add the following registry REG_BINARY value set to 01: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\UsbFlags\IgnoreHWSerNum0 4036001 Now install the driver again. After this the com port should not increment. Regards James Leary Support Engineer FTDI Ltd -- http://www.wearablesmartsensors.com/ http://www.softwaresafety.net/ http://www.designer-iii.com/ http://www.unusualresearch.com/
2010-02-28 by David VanHorn
>> when they are individually attached to the same USB port they do not >> attach to the same virtual COM port. You can go into Windows and >> change the port but that would be a pain in a lot of applications. It >> would be nice if you could tell the driver to "always use COM5" or >> whatever. The edgeport devices let you assign com port numbers to a physical device. When you plug a given box in to any usb port on your machine, it goes to the same com port assignments that it had been assigned.
2010-03-01 by stevec
Edgeport USB to serial box. I have 8 ports. Great software, if you need that many. eBay - has a lot of edgeport 4 and 8 port boxes. --- In AVR-Chat@yahoogroups.com, "Dave McLaughlin" <dave_mclaughlin@...> wrote:
> > I like the idea that is selects a different COM port as it allows me to use > more than 1 of the same type on the same PC. This allows me to add more > additional serial ports and in the past I have had 6 installed without any > issues whatsoever. > > > > Dave. > > > > From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf > Of David VanHorn > Sent: 01 March 2010 06:11 > To: AVR-Chat@yahoogroups.com > Subject: Re: [AVR-Chat] Re: USB to serial db9 cable > > > > > > >> when they are individually attached to the same USB port they do not > >> attach to the same virtual COM port. You can go into Windows and > >> change the port but that would be a pain in a lot of applications. It > >> would be nice if you could tell the driver to "always use COM5" or > >> whatever. > > > > > > > [Non-text portions of this message have been removed] >
2010-03-01 by Dave McLaughlin
I like the idea that is selects a different COM port as it allows me to use more than 1 of the same type on the same PC. This allows me to add more additional serial ports and in the past I have had 6 installed without any issues whatsoever. Dave.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of David VanHorn Sent: 01 March 2010 06:11 To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] Re: USB to serial db9 cable >> when they are individually attached to the same USB port they do not >> attach to the same virtual COM port. You can go into Windows and >> change the port but that would be a pain in a lot of applications. It >> would be nice if you could tell the driver to "always use COM5" or >> whatever. [Non-text portions of this message have been removed]
2010-03-01 by Bob Paddock
On Sun, Feb 28, 2010 at 10:05 PM, Dave McLaughlin < dave_mclaughlin@nerdshack.com> wrote: > > > I like the idea that is selects a different COM port as it allows me to use > more than 1 of the same type on the same PC. > The "every time I plug in I'm a new COM port" problem really confuses non-computer people that use my products. -- http://www.wearablesmartsensors.com/ http://www.softwaresafety.net/ http://www.designer-iii.com/ http://www.unusualresearch.com/ [Non-text portions of this message have been removed]
If your product is designed to run with your on software you should consider using the likes of the DLL from FTDI (assuming you use the FTDI devices) as this will remove the issue of knowing what com port it is on. The COM port option is really only applicable to a device which is going to emulate the standard com ports. The DLL option is a much nicer way of installing your system and it gives you greater control. Dave.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf Of Bob Paddock Sent: 01 March 2010 18:02 To: AVR-Chat@yahoogroups.com Subject: Re: [AVR-Chat] Re: USB to serial db9 cable On Sun, Feb 28, 2010 at 10:05 PM, Dave McLaughlin < dave_mclaughlin@nerdshack.com <mailto:dave_mclaughlin%40nerdshack.com> > wrote: > > > I like the idea that is selects a different COM port as it allows me to use > more than 1 of the same type on the same PC. > The "every time I plug in I'm a new COM port" problem really confuses non-computer people that use my products. [Non-text portions of this message have been removed]
2010-03-12 by Ned Konz
On Wed, 2010-02-24 at 05:06 +0000, Donald H wrote: > > --- In AVR-Chat@yahoogroups.com, Leon Heller <leon355@...> wrote: > > > > On 23/02/2010 23:00, rsimonus wrote: > > > I am curious about USB to serial db9 cable. I am planning to buy one. I want to know if any USB to serial 9pin cable which will work with any device and my old Sony Clie or it is depend on brand and model? I see walmart sell those for $9 dollars. > > > > The ones with an FTDI chip usually work OK. There are some with a > > cheaper chip (I forget what they are called, something beginning with > > P?) but they often have problems. > > Prolific PL-2303 > > These have been around for a long time and work very well. > > One thing you have to understand, after loading the driver for the first time, the USB dongle will be assigned a serial port number by Windows. > > If you plug the same dongle into another USB port on the same computer, the COMx port number will change. But if you plug it back into the original USB port, the original number will be assigned. > > This is Windows, not the dongle. > > I have not found any USB-2-serial dongle that will keep the COMx number the same across USB ports. > The last time I was forced to use Windows, I was able to assign a fixed COMx name for my USB serial adapter. Something like: Control Panel/System/Hardware/Device Manager /Ports/<port>/properties/Port Settings/Advanced.../COM Port Number
