AVR-Chat
Bad signature error programming with Avrdude
2010-04-28 by Brewski
Using an STK500 and an Olimex board on 3 different mega8515 chips I get the following signature error, any ideas? Oh, a mega8535 programs perfectly on both the STK500 and the Olimex board. Of course the the Olimex boards are different, each was make for a specific chip, 8515 and 8535. This is on a Linux Ubuntu OS running Make and Avrdude. The code compiles fine, it is when Avrdude tries to program or erase the chip I get the error. This error was received trying to erase the chip in the Linux terminal. Also, I thought the -F option was to ignore an incorrect signature.
$ avrdude -c stk500 -p atmega8515 -P /dev/ttyUSB0 -e -F -U flash:w:sw-led.hex
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_recv(): checksum error
avrdude: stk500v2_program_enable(): bad STK600 connection status: Unknown (0x64)
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA8515 is 1E 93 06
avrdude done.  Thank you.
Mike Bronosky
Mike@Bronosky.com
Re: [AVR-Chat] Bad signature error programming with Avrdude
2010-04-28 by Jim Wagner
Never used avrdude from the command line but I wonder if its not all a
result of that first failure line = "command failed".
Jim Wagner
Oregon Research Electronics
> flash:w:sw-led.hex
> Unknown (0x64)
> Thanks,
> Mike Bronosky
> Mike@Bronosky.com
2010-04-28 by Clark Martin
> Jim Wagner
>> flash:w:sw-led.hex
>> Unknown (0x64)
I looked up the chip types using avrdude and I see an ATMEGA8515 listed
as m8515
ie, that should be:
avrdude -c stk500 -p m8515 -P /dev/ttyUSB0 -e -F -U flash:w:sw-led.hex
Clark Martin
Redwood City, CA, USA
Macintosh / Internet Consulting
"I'm a designated driver on the Information Super Highway"
2010-04-28 by enkitec@gmail.com
> listed as m8515
> ie, that should be:
     I have used AVRSP.EXE and AVRPP.EXE from
http://elm-chan.org/works/avrx/report_e.html
     They both auto-detect the processor type.  Why Avrdude doesn't do that?
     Mark Jordan
