USBtinyISP vs 64-bit Windows 7
2010-09-09 by Michael
Does anyone know if the USBtinyISP will work with 64-bit Windows 7? Unfortunately, I'm not getting much help from manufacturer. I was told that I need to emulate a few com ports and was directed to a program called Com0Com. Before running com0com, I checked to see which com ports were free. When I tried to install com0com a pop-up says : "The 32-bit driver cannot run under 64-bit system. Continue?" I've tried ignoring message/continuing installation and I also tried running in compatibility mode, but when I type : install PortName=7 PortName=8 I receive the following : "SetupDiCallClassInstalledERROR:0xE0000235" I'm so new at MCU/programming that I don't even know how to ask the right questions. I would appreciate some help. Thank you
