AVR-Chat
RE: [AVR-Chat] ISP for Tiny84
2011-01-24 by Tim Mitchell
----Original Message----
[mailto:AVR-Chat@yahoogroups.com] On Behalf Of Steve Hodge
Sent: 23 January 2011 22:05 To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] ISP for Tiny84
> The data sheet for the Tiny84 does not explicitly mention
> "ISP" but I assume
> it can be done because the manual for my ISPMkII
> programmer says it supports
> the Tiny84 with ISP.  Am I correct that the "Memory
> Programming" section of
> the data sheet is the relevant section and that I:
> -- leave the SPIEN fuse in its default programmed state
> ("SPI prog.
> enabled")
> -- pin "PA4 (ADC4/USCK/SCL/T1/PCINT4)" is the one that I
> connect to the "SCK" line of a standard 2x3 ISP header?
> The pins for the "MISO", "MOSI" and "RESET" connections
> to the header are
> pretty clear.  It's just this "USCK" one that has me
> (slightly) perplexed.
> I just don't want to design a pcb without first
> confirming.
See p168 of the Tiny84 data sheet, there's a table there that tells you which pins to connect
MOSI PA6 I Serial Data in
MISO PA5 O Serial Data out
SCK PA4 I Serial Clock
Tim Mitchell
2011-01-24 by Steve Hodge
Thanks.   Just out of curiosity, do you know why Atmel didn't just call this
"ISP", with a clear section heading labeled such, like in many other data
sheets?   This is my first excursion into the Tiny's.  Is this
characteristic of Tiny's?   Steve
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of Tim Mitchell
Sent: Monday, January 24, 2011 1:12 AM
Subject: RE: [AVR-Chat] ISP for Tiny84
From: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
[mailto:AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com> ] On
> "ISP" but I assume
> ("SPI prog.
> enabled")
> to the header are
> confirming.
Tim Mitchell
__________ Information from ESET Smart Security, version of virus signature
database 5812 (20110124) __________
The message was checked by ESET Smart Security.
http://www.eset.com
http://www.eset.com
